[Problem] Bricked Asus ROG GL771JW BIOS
Hi everyone, I have a GL771JW laptop where the BIOS got corrupted. I’ve spent weeks trying to restore it, but I can only find GL771JM BIOS.bin files. While that did bring the laptop back to life, it only works partially. I flashed the BIOS using a programmer and a clip. Does anyone happen to have the correct BIOS.bin file? Thanks a lot in advance! Best regards, Olly
Edit by Fernando: Thread moved into the „BIOS Problems“ Category and title customized
Hi, do you have a backup of the original BIOS chip dump?
No Sorry the PC was shutdown and cant start more so the BIOS was smasht.Then i Take the Dumpf from GL771JM this was a bin File…the original BIOS File from Asus for GL771JW ist Not a bin File that is the problem i have.
Best regard
Olly
Just send whatever original backups you have…
G771JWAS211.zip (2.3 MB)
thats only what i have about that bios.that is a original from Asus
I see… Write this file.
G771JW-211.rar (3.1 MB)
Thank you wery well ,i will test IT in the next day ……:+1:
Sorry my programmer was burnig under programming so i bay a new bios chip i will give you info the next days when it´s coming to me :rofl: :face_with_hand_over_mouth:
No worries, take your time, and good luck!
