G18 2024… not enough ID provided…(G814JIR, G814JVR, G814JZR…)
How many ICs on board? Board ID label on PCB? G615J-PMV-PAL PCB 6050A3663705? AMI bios? Main + ME FW? Asus CAP file without header not suitable?
Usually, update fails on 2nd/3rd stages in ME FW, TB-PD/USB-C PHY fw etc… updates, you could try to rebuilt/clean your own dump main bios or probably just cleaning CSME FW region.
If CSME FW v16…not really plenty of resources/tools around…
2024 g814Jzr ,winbond w25r256jven, ASUS cap file same result pc booting rog logo, tried extracting and using bin file instead and that was a big no go , booting up a borrowed comp and getting as many things as u asked uploaded here shortly aswell as the orginal extracted corrupt bios file for u
update had failed I believe to either malware or bios instability ASUS been having issues with people who updated past a certain bios pc will just shut off no warning no nothing and crash file will just say rebooted, I suspect that could have been it of me tampering with settings prior to the flash
BIn simply renamed or CAP with removed AMI Capsule header? Have you ever recovered any system in such state? Do you have knowledge of these preocudures?
Just checked my repository, no bios backup or dumps to this mb
model (ROG Strix SCAR 18 - G814xxx) aka G834xxx, sry.
I dont need your file cause im not going to lose my time checking structure integrity of it.
Compare main bios volumes with Asus file or do the suggested earlier linked guide.
That’s all from me, you may wait for other users PoV, good luck.
EDIT: Went check Asus file, is not a ready file to use even after Capsule removed, it’s multiple volume UEFI fw, only for extract/swap/compare volumes/guid. You may need to look for alternative dumps from other sources if it comes to that as final solution.
thanks i kinda figured somthing like that was up and sorry was in a diff thread that was asking for pics of the stickers and everything, no i have never done this before, next step i guess is to buy an unlocked ebay chip for this model and extract and then write it so i don’t have to solder, no idea if that will even work but i appreciate you giving me some more stuff to research, delete what is not relevant picture wise,
I appreciate you at-least taking the time to show me how far off I am and give me more stuff to research and understand
