[Problem] Bricked ASUS Transformer Book T101Ha PC BIOS
Programmer doesnt care the size or content, right or wrong, as long as it fits the IC but yes the image for programming is 8192kb.
This may not be over… the upper block with ME region may also be corrupted or not, were assuming the corruption only affected bios region during the process.
If the ME FW region needs to cleaned/re-initialized, in your case TXE 2.0.5.3105, let’s hope not.
Perfect, thank you very much. I’m just asking you (since I didn’t understand) if you recommend I try to burn the rebuilt bios (T101HA_Final.bin) and see if the PC boots? And only if it doesn’t start, try to perform the β€œcleaned/re-initialized” link procedure? However, in the meantime, when I open the file (T101HA_Final.bin) in my analyzer, I receive this information:
I DID THE TEST WITH THE DUMP I HAVE AVAILABLE (THE ONE OF THE BIOS PURCHASED ONLINE COMBINED WITH 0x200 000 WITH ORIGINAL ASUS) WHILE WAITING FOR THE SOLDERING MATERIAL AND THEN DO IT WITH THE DUMP OF THE ORIGINAL CORRUPT BIOS.
Family β”‚ TXE β•‘
β•Ÿβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β•’
β•‘ Version β”‚ 2.0.1.2083 β•‘
β•‘ Release β”‚ Production β•‘
β•‘ Type β”‚ Extracted β•‘
β•‘ SKU β”‚ 1.375MB β•‘
β•‘ TCB Security Version Number β”‚ 1 β•‘
β•‘ Version Control Number β”‚ 4 β•‘
β•‘ Production Ready β”‚ No β•‘
β•‘ OEM Configuration β”‚ No β•‘
β•‘ Date β”‚ 2015-08-16 β•‘
β•‘ Size β”‚ 0x15F000 β•‘
β•‘ Flash Image Tool β”‚ 2.0.1.2083 β•‘
β•‘ Chipset Support β”‚ BSW/CHT
Everyone would follow this path…avoiding additional re-work when not needed.
TXE version can later be manually updated to latest available version (TXE 2.0.5.3117 / 2.1.5.3117), version is not a issue on getting the system alive…usually.
Okay thanks.
The txe version is generally not a problem for the functioning of the system, but it is essential for the boot β€œit must not be corrupted”.
However, once I have obtained the dump and rebuilt it, can I see the status of the β€œme fw” (if it is good) and test it on β€œme analyzer”?
The tool provides information, not really a firmware diagnostic utility, but it will detect β€œmajor” corruption, anyway i cant vouch any of my statements as i’m not the author of the tool or the best user to give you a full insight of it.
Ok, thank you and I’ll keep you updated on the work. I really hope the PC works again, not so much for the real value of the PC, but for personal satisfaction…
