The Ryzen 2400G is fine. Try this beta file
Thanks for sharing.
Iāve spent the last few days trying to get the motherboard to work.
First, I removed the heat sinks and other plastic components to eliminate the risk of a short circuit.
I then ran several tests:
The first was to clear the BIOS chip. During startup, the chipset heated up, but the CPU did not. The RAM LED stayed yellow.
Next, I wrote the latest file you shared and ran a verification. During startup, I saw the same behavior as usual: the CPU LED was red.
I then cleaned the motherboard, especially the socket. That didnāt change anything.
However, after repeatedly rebooting via the reset header, I managed to boot the board. I was then able to navigate the BIOS, just like on a working PC. Nevertheless, as soon as I shut it down, the usual behavior returned. CPU LED.
I suspect the processor power supply, even though the processor is running hot. However, Iāve never performed any work on these componentsā¦
