Hi. I have an ECS LIVA ZE Plus, which I tried to upgrade to the original BIOS (I had previously downgraded it), but I made a basic mistake. This is because the backup program only saved the BIOS sector (AMI AFU), and since I couldn’t update it using the program itself, I used an EEPROM programmer.
The chip has 16MB of memory, and the BIOS file saved by the AFU is 6MB. Before programming with the EEPROM programmer, I made a DUMP file of the chip, but it doesn’t seem very complete.
Furthermore, in the midst of all this, the MX25L12873F chip seems to have been damaged (or already was), because from the beginning the CH341a programmer can’t read it correctly (probably because of this the DUMP file doesn’t seem complete), and it only accepts programming of 00s and not FFs in certain sectors.
My question is if there is any way to repair the DUMP file using the backup file made by AFU?
BIOS version from AFU backup: 18.04.30
BIOS version in DUMP file: 17.02.16
Any help is appreciated, thank you.
PS: If you’re wondering why I downgraded, it’s because this computer didn’t display video when connected directly to HDMI; it’s necessary to use an active HDMI to VGA converter for video to be displayed even in the BIOS.
