[Problem] Bricked Gigabyte Z390 Aorus Elite BIOS
PC Specs:
• Motherboard: Gigabyte Z390 AORUS ELITE
• SSD: M.2 ADATA SX6000LNP
• CPU: Intel Core i9-9400F
• GPU: AMD Radeon RX 6600
• RAM: HyperX
It all started when I decided to update the BIOS on my Gigabyte Z390 AORUS ELITE to the latest version. I wanted to make sure everything was running optimally and planned to tweak my RAM settings a bit.
After the update, the PC booted up perfectly into Windows. I configured the RAM, ran stress tests, and everything passed with absolutely zero errors. However, as soon as I launched a game, the system suddenly crashed with a Blue Screen of Death (BSOD). I figured it was just a random glitch, but after the reboot, Windows completely vanished. When I entered the BIOS, the M.2 drive was still detected, but there was no Windows boot option available on it.
Thinking it was just a minor bug, I reset the BIOS to default settings, but that didn’t help—Windows wouldn’t recover. I tried repairing the OS using a bootable USB drive, but that failed too. I then downgraded the BIOS to the oldest version the motherboard would allow (due to capsule BIOS downgrade restrictions), but the issue persists.
The strangest part is the installation loop: I can successfully install Windows from a flash drive, and it boots up fine the first time. But as soon as the PC reboots, the OS disappears completely again. I suspected the M.2 drive was faulty, so I tried installing Windows onto a standard HDD instead, but the exact same thing happened. I also tried booting with only a single RAM stick installed, but nothing changed—the OS still gets corrupted or wiped instantly.
I’ve already scanned the M.2 drive for bad sectors and errors, and it passed completely fine. I also tested the RAM in different modes, and there are no errors there either. I have crawled through every single setting in the BIOS, toggling various drive and memory configurations, but nothing works.
I am completely stuck and don’t know what to do anymore. Has anyone ever encountered anything like this? Prior to the BIOS update, everything was working flawlessly on the old version. I can’t roll back to that specific version due to the capsule lock restrictions, and the older one I managed to flash didn’t fix it. Taking the PC to a repair shop is not an option right now, as I live in a remote rural area and there are no service centers nearby. Any help would be greatly appreciated!
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
The capsule is not a problem.
Study the forum, and you will find a solution.
The programmer is capable of a lot.
All the problems went away when I changed the power supply, the old one degraded and caused problems
