[Problem] Bricked Lenovo IdeaPad 3 BIOS
At this point I’m just begging for help, I’ve asked in a lot of places and have gotten no answers
I have a IdeaPad 3-15ALC6 Laptop - Type 82KU, serial number PF4DAS6A I forgot the password of the computer and I was using only the pin, but yesterday there was a lenovo update that made “changes in security policies” so I neede to insert the password, so I did the classic of flashing a windows image, and from the installation screen, change the name for utilman and copy and rename cmd to utilman to then create a new admin account, change the old password of my computer, and then remove the temporal admin account after that I removed the cmd called utilman, but I couldn’t rename the utilman.exe.bak to just .exe, so I just keep it like that, without the utilman, and it worked perfectly.
After restarting the computer, it now won’t turn on, the keyboard lights turn on but there is nothing on screen. I tried discharging the remaining power to restart, then do the same with AC unplugged, removed the SSD, removed RAM and SSD, unplugged and plugged again the CMOS battery, and nothing is working, so after reading some posts here and asking both chatgpt and gemini, I got to the conclusion that it was a BIOS fault
I found this post that seemed to help a lot of people https://www.reddit.com/r/LenovoLegion/comments/1goprvx/is_it_possible_to_recover_corrupted_bios_with_usb/
So after checking the version of my bios I downloaded glcn68ww.exe, after extracting it with 7zip, instead of a normal file like the forums and post say, my biggest file was ‘[0]’, but I tried anyway
I’ve tried multiple names: n0cn.bin, nscn.bin, BIOS.fc, GLCN68WW.bin.
When I do ‘Fn + R’ the power buttons turns orange and blinks as it should do, but there is none bios beeps nor fan spin.
I don’t know what else to try
At this point, I just beg for help, if there’s any extra info needed, I can provide it
Edit by Fernando: Thread moved into the “BIOS Problems” Forum Category and title customized
What a 'mess" sir… couldn’t you give some more effort and “kill” a system a bit deeper… i mean you’re past the point of using any official Lenovo firmware recover.
Use more “Reddit” pros and AI pros… they will fix it for you…
Pay the service now to a Tech IT Professional.
