[Problem] BSOD after Coffee Time Mod
After coffee time mod i experience general system instability:
Bsod codes: Driver irql not less or equal, irql not less or equal, kmode exeption is not handled.
Cpu: i5 8500
Moboard: Asus Prime H270-Plus
Bios ver: 2001, 1205. ME: 1.7.1229 Con if im not wrong.
Please help me fix it. I got performance but because of instability i cant enjoy it.
I can add screenshots of Reliability Monitor and WhoCrashed. Im begging, please help :sob:
@Senpai78s did you flash it using ch341a, or afuwin /GAN method?
If you use afuwin /GAN method, do you understand to use mod grub to set bios lock to disable and enable intel me fw reflash (so that afuwin can write the me region)?
Also, please provide your own bios dump and send it here or through transfer.it :slight_smile:
Ill dump bios rq.
I used ch341a and AsProgrammer to write the bios. List of every change in bios i did: rolled back ME from 11.8 (i forgot version) to11.7.0.1229 Con disabled, From Pci to 16t+ patches are done, Gop and vbios driver updated to latest versions that are set in coffee time. Fd locks, Pci 1440 are not patched. Microcodes for U0, B0, R0 (to run old cpu too).
Extra tab:
Bios lock on, default memory speed is auto, Hex to Decimal patch applied.
Stock bios is available on asus site.
I had suspected overheating as a problem but in tasks such as minecraft mod packs, blender, roblox studio everything works fine untill i get random bsod and thats all. All thermals are under 70°C, i even added fan to cool vrm heatsink.
Additionally after everything i had experienced, i did undervolting: offset mode -0.065V, PL1=60W, PL2=80W. IA AD/DC set both to 40, CPU Load-line Calibration set to 3.
@Senpai78s All right, i’ll be waiting for your bios dump. Did you already transfer the motherboard original credentials like sn, uuid, and mac address? also, did you do the pin isolation and pin connect/short correctly?
If you still have the original bios, and if you don’t mind, could you also include the original bios dump?
Use transfer.it to send the dump if you could not send it here, let’s keep every dump as-is :slight_smile:
3 more things:
During any mild load like opening file my mouse slows down.
When i move any window it start to lose frames on high speeds. Same for scrolling some programmes like Open Hardware Monitor. Scrolling down is slow and glitchy, and same goes for task manager.
When i run my old cpu everything is fine.
I have bios without mac1 or 2. Here they are: Transfer.it
I did send i just forgot to make it a reply: Transfer.it
Okay, i’ll brb with my version of the mod :slight_smile:
@Senpai78s Senpai78sMod.rar (7.5 MB) Here you go, just directly flash using ch341a :slight_smile:
I also added ReBarDxe and NvStrapsRebar in case you do want to use rebar, and how to activate it you can read this post, also to enable Intel PTT (fTPM) just go to pch fw configuration.
It took me a while because there is a manual fix i did using hex editor (readjusting the Image base in TE Image of PcdPeim).
Alright, big thanks for your time you gifted me by doing all that! I will try to flash it right now.
Lets hope everything will run great! I will read post on the provided link. And after flashing i will tell how it all went!
I do hope everything went well, also the one i sent to you was with the SN and UUI of your bios implemented. I have the clean stock modded version. Checked pad files and everything is 1:1 with stock bios. Disabled Bios Lock setting in the bios too.
Intel PTT should work normally because it’s the ME is enabled (remains unchanged), i used ME FW 11.7.0.1261 for this Bios.
Under “PCH-FW Setting”, just set Intel PTT to Firmware TPM or Software TPM, since the default is Discrete TPM and i didn’t change it. Under PTT Configuration, it should show PTP Aware.
If your gpu is Nvidia Turing (GTX 16xx/RTX 20xx) or AMD Polaris and newer, or even Intel Arc, just read the “How to Enable Resizable Bar” section, it should be simple for you to activate it. And if it succeed, could you make a screenshot similiar to this:
I will make a post if the bios i provide to you succeed and didn’t cause any BSODs/Issues while navigating the bios anymore with your normal usage.
Probably latest thing i will ask: I always did first erase ic, then write ic, and last was verify ic. I do it right?
Yep, just read, erase, blank check, program/write, verify
if each step are succesful, bios is flashed succesfully
We got a boot, for now i change:
Above 4gb decoding, because of my gtx 1660 su.
CPU voltage: Offset mode: -0.065V.
Secure boot: Windows UEFI, if cause the error i will switch back to Other OS.
Dram speed is set to 2400.
I will contact tomorrow’s evening and tell if i had any issue.
For this, after you enable Above 4G Decoding, just run the nvstrapsrebar executable as admin from thag post, press E, press P, type in 32 and enter, press S, exit, and reboot. It should run rebar if booting sucesfully.
For secure boot, if “Violation Invalid Signature Detected” after enabling Secure Boot and installing the keys, i think that is normal, the only way to fix it as per what i’ve known is by clean installing the OS.
For TPM, you can enable it later if you want to.
After you’ve done all of that, do your own voltage/offset settings you’ve mentioned before, and use your pc like usual and see if the OS will BSOD once more.
I’ll be waiting for your results (and the screenshot) later, enjoy :saluting_face:
Please help me just last time, i wont bother you any more. Even if you refuse im still thanking you for the help!
Alright, no more imminent crashes and system is stabile in ram, gpu load, but reliability monitor shows damn alot of Antimalware service executable has stopped. I will try clean os installation.
Crashed after i tried to do cpu stress test. Probably thermals aint right.
Sorry for different language im from Poland.
I guess this is perhaps a good time to nuke the OS.
But before that, just make sure both secure boot are enabled alongside with the keys are installed, and intel PTT is enabled at software/onboard tpm (anything other than discreet tpm), and dont forget to enable abive 4g decoding, then select the installer usb drive as the 1st drive option, save and exit, and boot off the usb drive.
Nuke the OS partition only, and install the os onto the cleaned partition.
But before all of that, could you take the screenshot of what i’ve asked before?
Mr i have 3090 and on X299 official has ReBar but can i increase mb on BAR0 BAR1 AND BAR2?
Just enable rebar at bios after enabling above 4g decoding, and the bar should assign properly.
Yes but can i increase BAR0 BAR1 BAR2?i have another question how can i increase MMIOH and MMCFG? thanks a lot
Maybe i found it is this?
