Hello,
I have a Gigabyte Aorus 15G KC laptop.
It is equipped with an Intel i7-10875H processor and an Nvidia GeForce RTX 30 Series GPU.
I am unable to install Windows because a BSOD (Blue Screen of Death) occurs during the installation process. I can access the BIOS.
I managed to get Windows 10 running on the Gigabyte laptop by installing it onto a SSD using a different computer (which also had a 10th-generation Intel processor) and then moving that SSD into the Gigabyte laptop.
I performed a BIOS update using the Gigabyte utility within Windows 10. After flashing the BIOS, I was able to install Windows 11 and used the laptop without any issues for a week.
Now, the problems have returned:
- Windows 11 no longer boots and displays a BSOD.
- It is also impossible to boot from USB installation drives, as a BSOD occurs in those cases as well.
Thank you for your help!
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
Can be if bios settings are being reset by low voltage CMOS battery, it reverses disk mode operation not matching the mode that initially Windows OS was installed, best performance is UEFI with AHCI disk mode, NVMe or SATA SDD.
Hello,
Thanks for your answer.
I installed a new CMOS battery, but the problem persists.
There are error messages with the BSOD
“machine_check_exception”
“kmode_exception_not_handeld”
“WHGA Uncorrectable error”
Too much to deal on a forum sir, laptop needs proper diagnostic… if not a bad install media, then it could have hardware issues, get it to a professional tech service.
Ok.
I would like to test a BIOS downgrade but I can’t do it on Windows because it doesn’t boot and there is no flash utility in the BIOS.
Do you know if there is a bootable utility to do the downgrade?
Not for Gigabyte laptops, only OS recover F9, downgrades most likely have to be done like SPI IC device re-programming, and your issues doesn’t seem to be bios version related…there’s no miracles/fix in bios flash or downgrade, like “common” users seems to think or bull “nonsense” AI advised…
Bios FB07 defaults loaded, a correct/official USB OS install, clean disk GPT installation, if it fails most likely to be system HW issue, that’s it, nothing more toa dd to this subject of yours, good luck.
