Hello everyone, first post after years of lurking in this absolute treasure trove of a forum.
While going through my old crap I came across this old Asus B150M-A-D3 board (which worked for years with an early ES skylake chip) and an i3-8100 that I also used for a long time with a coffeelake modded h110 board, and decided it would be a brilliant idea to marry the two.
Long story short, no amount of modding seems to result in anything working, with the current modded bios (courtesy of the old coffeetime 0.99) all I get is what sounds like a normal boot (fan spinning up and then coming back down, power button works to power down the sysrtem) but no post and no beep codes.I’m currently trying a lightly modded 2604 bios (latests available for the board, should go up to kaby lake) with just the PCIe patch, the “NO_CAP fix” applied (no idea if it actually does anything for this particular board), “FD locks” unlocked and the microcodes for 906EB (EA), which should be the correct ones for the stepping of my CPU (see attached screenshot).
Any idea or pointer for stuff to test would be greatly appreciated as I am totally stumped on this one. Also, does anyone have any suggestion for a good post analyzer that works on modern-ish systems?
@the_thinkerer I think it is because you use COR instead of CON, since your board uses COR intel me.
Anyways, i assume you did use a hardware programmer, or maybe managed to unlock the whole flash descriptor and able to use intel fpt to flash the whole bios chip, you could try these bioses i’ve mod, just don’t forget to transfer your SN, Mac, UUID.
The difference between MEon.bin and MEoff.bin:
Since i didn’t look further if 11.7.0.1261 COR + ON could boot, you could try to flash MEon.bin first and use any skylake/kabylake processor (normal ones, not ES/QS one, but you could try) and see if it boots, then try to use coffeelake. If coffeelake didnt work (but skylake and coffeelake does), then go with MEoff.bin, it should work. For the microcodes i inserted them using MMTool, and did fix the FIT table, before doing any of the mods. With ME Disabled (which is in MEoff.bin), you can’t use Intel PTT.
Resizable BAR is possible if the System Agent (SA) Configuration menu is shown under advanced menu, just enable Above 4G MMIO, then use this for gpus that supports rebar natively, or this if you use nvidia turing (GTX 16xx/RTX 20xx).
Thank you for the pointer and the bioses, I didn’t really think about messing too much with the management engine.
Hopefully I still have a suitable CPU kicking around somewhere, otherwise I’ll have to go straight for the de-ME-ed one, in any case I’ll test and report back.
I did manage to test the no-ME version so far and still no luck, but I may have overlooked something important: I never bothered to isolate and bridge the pads, as on the other board (biostar) it was not needed and I was under the impression that it only applied to the non-quad-core CPUS, any thoughts?
Expanding on my research: the B0 stepping CPUs should not require any isolation or bridging the SKT_OCC pad, so I should be good there.
In any case, before confirming this fact I did manage to find a boardview of the mobo and looked around for easy ways to accomplish the bridging since the conductive tape/paint trick is never fun so I’m leaving this here for future reference.
The easiest way to do the bridging would probably be to remove the cap in red altogether and replace it with a solder blob to ground.
Anyways, still not giving up for the time being, but kind of tempted to just go back to the original non ideal configuration and call it a day.
Did you still use the ES skylake chip or any chip that supports that board natively? I didn’t include 506E0,1,2 (SKL ES-QS) and 8 (KBL ES) mcode in the bios that i shared to you…
Sorry, I failed to clarify but I only used the coffeelake chip (i3 8100), as the skylake ES is a bit of a pain in the butt to install since it’s also been delidded.
I will probably go ahead and reinstall it in the next days and I’ll take the chance to try to add the 506E0 microcode to one of the modded versions and give it a go.
@the_thinkerer If you don’t mind testing, i re-did the bios, the link is still the same in the previous comment above, with all microcode (506E0,1,2,3,8 and 906E9,A,B,C,D) added and FIT Table corrected (you can open the files itself on UEFITool). All i did was redo the bios mod from stock bios (again), up until the ME part, which i use ME FIT v11 for each bioses (so modded bios from stock, making sure no padding issues, and copied that bios 4 times for each ME Firmware replacement rather than using coffeetime, and each firmware is RGN for FIT purposes, not EXTR).
This time, it have 4 variants;
- MEOn.ROM is using 11.7.0.1261 Corporate H-DA Enabled
- MEOff_11.7.ROM is the HAP Bit Disabled version of MEOn.ROM
- MEOff.11.8.ROM is using 11.8.97.4739 Corporate H-DA Disabled
- MEOnCon.ROM is using 11.7.0.1261 Consumer H-DA Enabled
Testing! Will report back shortly, thank you for what I assume was a lot of work doing everything by hand!
Still no luck, I’ll bite the bullet and swap back everything to the last known good configuration to double check everything still works.
So didn’t any of those bioses (the me disabled one) works with Skylake ES/QS? I wonder if the ME disabled bios would work with the ES.
Sorry, I think I’ll be forced to throw in the towel on this one.
The ES, which has always been extra finicky and particularly janktastic (I’m working with the bare die, no IHS and no retention mechanism) is currently not giving any sign of life with any of the bioses, including the original backup.
The 8100 also didn’t work with any of the old or the new ones, but happily came to life when I popped it back into the modded H110 board it came from.
