[Problem] Corrupted Lenovo Legion Y740-15IRH BIOS
HI my model is y740 15irh legion 81uf. i used ch341a programmer with an online bios and it worked the first time after 30 min, and tpm was corrupted to 0.0.0.0 .
so to fix that i tried to flash my original and other bios and now the laptop does not power on but i see a ACpower adapter light and when the power button is pressed the ports lit up and disappeard in less than 5 sec.
not sure if this was hardware issue or i corrupted bios or EC.
can anyone help.
Screenshot_20260829_125823_Gallery
Original bios with invalid undeorvolt
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
So resuming…you tried to mod your own bios (Undervolted) and broke the system, then you got a bios from an unknow source and it worked, then you flashed the already original broken/undervolted bios mod that was on the system and kill it for good.
If so, it’s pretty obvious right? You returned to initial point…a bad mod and did it worst.
So, no original backup with SPI programmer BEFORE any mod attempts?
I can share a work bios…LA-G132P motherboard or NM-C371?
Full story”
When laptop was working I made a undervolt in bios and the laptop got a blank screen , but it powers the keyboard light.
So I made a back up of this original bios using ch341a, but this has an undervolt which should atleast lit the keyboard light, with blank screen.
So online I found a bios for 15irhg, and I flashed it to fix the undervolt, it worked after 45 min and tpm got corrupted, when I verified in windows it says not tpm and in bios its displaying 0.0.0.0.
So to fix the tpm i tried a new bios again online downloading from official lenovo website and changing with hex and it did not work and I kept on trying different bios version that also did not work. And finally I tried my original bios which I attached with corrupted undervolt even that did not even lit the keyboard light . It basically lit the port light for few seconds and disappear.
I also took a backup of the working bios with corrupted tpm and I flashed it again and it does not work .
Currently I have the original bios flashed with incorrect undervolt values and the laptop does not power on just the port light lit and disappear, but initially for this bios atleast the keyboard light were coming.
So the current state is port light lit and disappear when the power button is clicked, so not sure if bios Is corrupted or the ec is corrupted or the chip is fried .
Was using ch341a which produces 5v. May be should have converted to 3.3v.
Machine details:
Machine Type Model (MTM)
81UF0000US
Full model name
BIOS platform string
Y740-1517IRH
Motherboard / schematic model
Compal LA-G132P Rev 2.0
BIOS chip
Winbond W25Q128JV, 16 MB
Intel platform
Coffee Lake-H / Intel CSME 12
So, i was right you have done an irresponsible mod without first doing a proper full system Firmware backup and the original one is broken after the mod attempt, so as is said i can only share some working dumps, with the proper motherboard ID.
The initial CH341A device had indeed this issue, not the latest ones, Black or the 1.7 version.
I have the black version
This file can work or not, depending on GPU
Another one:
Report it, that’s it from me, good luck.
I have 1660ti gpu, i will first do the ELPY5 as that is written on my motherboad.
Not sure but clearing the ME region and clean bios will help or not.
I will try and let you know.
I hope it’s not a motherboard short.
@MeatWar I tried flashing the 2nd bios ELPY5 but did not work have the same issue the usb ports light up for few seconds and disappear.
The AC POWER light is always on.
I also tried multimeter, which has 5v and 3 v working fine ,but the jp3v and jp5v is 0. Jp3v and jp5v are on the backside of mobo.
Seems no flash will fix it and wasn’t the initial problem, need deep circuit analysis on power and that EC.
Good luck.
@MeatWar The legs are so tiny I cannot use multimeter to test , also JP3V to ground is OL/infinite with power disconnected.
I might need to visit the repair shop. If expensive might buy a mini pc.
Are there adapters for multimeter.to test the tiny legs as U21 is very small.
thank you for all the help, i will update the post when ever there is a progress.
There are quite a few people in other forms who had the same issue with out a solution.
@MeatWar finally good news, I was able to make it work just by shorting the bios. And it worked , I literally flashed like 20 times thinking the bios was corrupted or the mobo was shorted .
I am scared to do that again, but it’s inevitable as i need to do it again as the TMP was corrupted and in BIOS it says 0.0.0.0 .
I flashed one of the last working backup I saved .
So now the question is how to fix the TPM.
Aah , I just connected the battery and now it does not power on so I removed the battery again its not working now.
Not sure something is not right.
I need to short the CMOS pins for the laptop to switchon…
That is CSME FW corruption.
Then as suspected…besides corruption, the system has issues at circuit level.
My advice is to look for a professional tech on circuit level repair and avoid further damage…
I was finally able to flash my first original bios , I was able to fix the undervolt issue using chatgpt and after flashing it worked fine.
I still some times see laptop not powering on after shutting down and removing the power adapter.
I just need to clear the CMOS , for it to power on , not always happens 1 out of 5 times.
I can live with that, probably will change the CMOS battery and check.
BUT anyway happy it works , as i don’t remove the power adapter for the laptop that often.
Finally changed the CMOS battery and now every thing looks smooth. All works.
Now i am thinking, maybe it’s not the BIOS issue just the CMOS battery issue.
So, no more 0.0.0.0 from CSME FW…???
EDIT:
Oh…now it’s explained.
@MeatWar
Yes. no more 0.0.0.0 , But i flashed my original first bios and reverted the undervolt value to 0. which fixed the TPM issue.
But the power on issue is CMOS battery related .
