[Problem] Dell Latitude 5531BIOS recovery after update
Hi everyone,
I’m a laptop repair technician, and I’m looking for some help with a Dell Latitude 5531 that has me completely stuck.
The customer brought it in after a BIOS update failed. According to them, the laptop powered off during the BIOS update, and since then it hasn’t powered on properly.
I’m still relatively new to BIOS repair, but I’ve already tried quite a few things:
  • Backed up and analyzed the original BIOS dumps.
  • Cleaned the ME region.
  • Replaced the BIOS region.
  • Sent the dumps to someone with much more experience in BIOS repair, who also cleaned/rebuilt the ME region.
  • Tried several BIOS files from different sources for both this motherboard and other Latitude 5531 systems.
  • Rebuilt the image with Intel FIT after replacing the MFS/EFS partitions.
Unfortunately, nothing has solved the issue.
The link for the original files:
The motherboard has two SPI flash chips:
  • 32 MB
  • 16 MB
Current behavior:
  • The fan starts spinning.
  • Black screen.
  • No POST.
  • In most cases, it just stays in this state.
With a few BIOS combinations, I managed to get the Dell logo. The laptop then restarted twice with the logo before shutting down again.
The previous person who looked at the BIOS believes this is not a software/BIOS issue. However, considering the customer’s description (the system shutting down during a BIOS update), I still suspect the firmware is corrupted in a way that isn’t fixed by a standard ME cleanup.
When analyzing the dump with ME Analyzer, I get the following message:
Detected MFS Low Level File 269 which has not been parsed!
I’m wondering if the firmware needs more than just an ME cleanup—perhaps there’s corruption in another region.
I’d really appreciate it if someone with experience in Dell BIOS recovery could take a look at the dumps or point me in the right direction. At this point I’ve exhausted all the usual methods and I’m out of ideas.
System information:
  • Model: Dell Latitude 5531
  • Service Tag: 8CFBPL3
Thank you in advance for any help or advice.
Edit by Fernado: Thread moved into the “BIOS Problems” Category and title customized
Here’s a working Latitude 5531 Wistron BM15 MLK UMA MB 213002 dump of both ICs, since you have the original backups with it’s own data, try these and if works all you need is to edit the Dell data.
Thanks for sharing the dumps.
I tried them, and the behavior changed. The laptop now restarts three times, the display backlight turns on, then it shuts down and the LED flashes 3 amber, 4 white.
My motherboard is 203117-1 (1TTPY$CA), while yours is Wistron BM15 MLK UMA MB 213002, so I believe they’re different board revisions.
I’ve also tried every BIOS dump I could find online for this model, but none of them worked properly. According to ME Analyzer, my original dump has a Corporate ME firmware.
Next time, provide the correct and CRITICAL information…used by every “Laptop repair tech…”
I do not have dumps or schematics of the stated model, WISTRON BROADMOOR15P MLK 203117
yes, sorry, my bad. Do you have any idea? Can be the BIOS that corrputed? i mean is there cases where the ME and the BIOS region is not enough to replace?
It’s clearly a firmware corruption when it’s interrupted, now it can in the 32 or 16, excluding this if a successful CSME clean/reinitialization was done correctly using FIT, in this case only remains the main fw.
Now…there’s several other ICs with data, lile USB-C PHY etc…we don’t know what the Dell package contents and target operations.
You can extract the Dell package and swap volumes with UEFI tool…a “needle in a barn” sometimes.
Thats all from em, good luck.
Thank you.
Yes, I already extracted the correct BIOS update version, but I’m not sure how to replace the individual modules correctly.
I tried searching for the module patterns in the BIOS image using HxD, but for some of them I couldn’t find any matching data. Are those modules encrypted or compressed?
For example, I couldn’t locate the Gigabit Ethernet, Intel TbT Retimer, or Emza Sensor Controller modules.
I couldn’t find any guide online explaining how to replace these modules properly from an extracted update file.
One more question: I’m sorry for disturbing you, but i think i tried to replace the BIOS region in a wrong way. I searched for the bios region, and i just simply replaced with the update file’s bin, but i think this is not how it works. In the update file which is 24MB (System BIOS with BiosGuard v 1.33.0) i have no footer for example. So the end of the file is just empty… What is the way to do this? Open both files with UEFI tool and replace all the volumes one by one?
Thank you.
There’s the extract version “NE” one and the edit/regular one 0.25/0.28, of this tool.
You can swap regions, volumes, files, sections, modules etc…
Some swap’s locations can blank default original Dell system data, loosing SN, UUID, MAC etc…This data can often be retrieved from the current corrupted dump and manually edited and restored to original location, often done with Hex editor or pad swap.
Often is made a comparison via a Hex editor to check for diff in data, trying to narrow the corruption and location address of this data/address location. Data can also be swapped/overwritten with Hex editors instead of UEFI tool, as long as the user knows what is doing, a small bit address location can be fatal.
Corruption can be in Main bios or CSME FW data IC’s, your motherboard has one for each data if not mistaken.
The extracted Dell files are not structured as the plain dump image with regions, so size is not the same, what matters is the content to work with.
Sensible data protected (UEFI tool Yellow/Red) by BiosGuard and others security measures, cannot suffer medications as it will lead to errors/system break.
It’s not an easy task for unfamiliarly users, and this is user time consuming so you won’t see may offers from users to do this.
