[Problem] Dell OptiPlex 7090 SFF with dead PCIe lanes
Hello gentlemen, I have a situation that ruins my sanity with this Dell 7090 witch had an admin password set. While I was desoldering the BIOS chip I managed to fry it before I could read it. I flashed the BIOS from another unit and the PC posted. After adding the M.2 Drive it didn’t showed up in the BIOS, nor in the Windows installer, the network card and the PCIE x16 are also dead. A SATA SSD works, all USBs except the type-C are working and the Wi-Fi is working too. After some research I found out that the PCIE lanes are controlled by the Management Engine and I overlooked cleaning it before flashing that BIOS. By reading the guide provided on this forum I used Intel FIT to clean the Management Engine. After flashing the BIOS the PC powers on and results in a 3,6 diagnostic LEDs that, according to Dell, means “SBIOS Flash Corruption”. No matter what version of ME I used (always used the Corporate SKU, so I haven’t mismatched the SKUs), the exact same as the BIOS, a previous, or a later version it always triggers these diagnostic LEDs. Basics like “remove CMOS, let it sit for 10 minutes, press the power button for 30 seconds” also not working. Thank you for your time, gentlemen!
Edit: All the keys related to BootGuard are matching.
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
UPDATE:
I fixed this issue by disabling FPF Hardware Binding, CPU Debugging and BSB Initialization using FIT 15.0.21.1549. I used the BIOS Region and the ME provided by Dell in the .RCV file. I reinserted the Windows DPK only after the machine started working again because any previous attempt to transfer NVRAM/Dell DVAR Store from the older BIOS would trigger 3, 6 diagnostic LEDs regardless of FPF binding, etc… status.
