Thank you for the suggestion – unfortunately it looks like same result:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
DRAC7=> setenv bootcmd 'fwu boot' iDRAC7=> saveenv Saving Environment to SPI Flash... Erasing SPI flash at 0x100000...Writing to SPI flash...done Erasing SPI flash at 0x110000...Writing to SPI flash...done iDRAC7=> fwu mmc sd Erasing SPI flash at 0x100000...Writing to SPI flash...done Erasing SPI flash at 0x110000...Writing to SPI flash...done iDRAC7=> fwu boot OS_WDT0_EN:180 seconds, Re-load ILRAM: Boot Path Retry:P1/N=3 P5/N-1=3 Recover Re-load 0x1000Kbytes from u-boot offset 0x0 into ILRAM at 0x0 Force Address Error to reset iDRAC U-Boot 2009.08-00066-g951a018 (Apr 30 2014 - 13:44:13) Avocent (0.0.3) EVB, Build: jenkins-idrac-yocto-release-483 CPU: SH-4A BOARD: R0P7757LC00xxRL (C0 step) board BOOT: Secure, HRK generated DRAM: 240MB (240MB of 256MB total DRAM is available on U-Boot) ENV: Using primary env area. In: serial Out: serial Err: serial WDT2: Booted Lower Vector, 'uboot1' sh_mmcif: 0, sh-sdhi: 1 Net: sh_eth.0, sh_g_eth.0 INFO: 00:002 Start-up -to- util_idrac_main() INFO: 00:004 U-Boot 2009.08-00066-g951a018 (Apr 30 2014 - 13:44:13) Avocent (0.0.3) EVB INFO: 00:008 U-Boot checkin date(05-10-2013) Version(1.0.183) INFO: 00:006 iDRAC PPID <NULL> INFO: 00:003 SPI NOR init 4096 KiB AT25DF321A bus=0 cs=0, speed=1000000, mode=3 INFO: 00:008 SH-4A Product: Major Ver=0x31 Minor Ver=0x14 C4 Little endian Family=0x10 Major Ver=0x30 Minor Ver=0x0b PASS: 00:015 Dedicated monolithic mgmt NIC disabled INFO: 00:129 BCM54610 OUI=0x3fffff Model=0x3f Revision=0x0f PhyAddr=1 INFO: 00:155 SD CARD: Device: sh-sdhi Manufacturer ID: 27 OEM: 5048 Name: SD08G Tran Speed: 25000000 Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: -620756992 INFO: 00:058 EMMC: Device: sh_mmcif Manufacturer ID: 90 OEM: 14a Name: HYNIX Tran Speed: 25000000 Rd Block Len: 512 MMC version 4.0 High Capacity: Yes Capacity: 0 INFO: 00:019 CPLD: Major Ver=0x1 Minor Ver=0x0 Maint Ver=0x3 Planar: Type=0x04 Rev=0x8 Rework=0x0 Scratch/PathRetry=0x0f PASS: 00:014 Coin cell detected good, AD=0x391 low water=0x2c1 PASS: 00:008 PCIe C0 Ver=0.15 MCTP en, CRC=0x8e9b6875 @0x8efbf954 cnt=0x18000 INFO: 00:007 Init PCIe mailbox(PCIe 0xFFEE0150=0x40010000) INFO: 00:005 mode=normal INFO: 00:003 reset_cause=recover PASS: 00:005 Booted Lower Vector, 'uboot1' wdt2cnt=0 INFO: 00:005 wdt0cnt=0 PASS: 00:002 SMR0 no sermux env, default 0xd4 INFO: 00:004 GRACR=0x3c HISEL=0x00 SIRQCR5_D=0x03 SIRQCR6_D=0x01 LADMSK0=0xff2 MRSTCR0=0xfedffe7f MRSTCR1=0xfff3ff0f MRSTCR2=0x7f80feff BARMAP=0x1 BCR=0x85000000 NCER=0x01fc NCMCR=0x0006 NCCSR=0x0303 PASS: 00:022 etherc0=F0:1F:AF:CF:17:7D getherc0=F0:1F:AF:CF:17:7E INFO: 00:007 Fan logic is not modified on Non-AC power up INFO: 00:052 Env and backup CRC'ed ok Extended partiton size is 0x1bffff Clear beginning MASER, start_blk=0x126009 blk_cnt=0x7000 *** create default partitions *** No. Type Status Start Size System ----------------------------------------------------------- 1 P 80 1 8000 16 MB Linux 2 P 00 8001 37c00 111 MB Empty 3 P 00 3fc01 400 512 KB Empty 4 E 00 40001 1bffff 895 MB Extended 5 L 00 40002 8000 16 MB Linux 6 L 00 48003 37c00 111 MB Empty 7 L 00 7fc04 400 512 KB Empty 8 L 00 80005 a0000 320 MB Empty 9 L 00 120006 2000 4 MB Empty 10 L 00 122007 2000 4 MB Empty 11 L 00 124008 2000 4 MB Empty 12 L 00 126009 2c1001 1 GB Linux 13 L 00 3e700b 17d79 47 MB Linux 14 L 00 3fed8b 3001 6 MB Linux 15 L 00 401d8d 12c001 600 MB Linux 1 Unknown Image 2 Unknown Image 3 Unknown Image 4 Unknown Image 5 Name: sh-linux Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 0x26c395 bytes (0x1362 blocks) Load Address: 80001000 Entry Point: 80002000 6 Type: SquashFS Data Size: 0x38d15f4 bytes (0x1c68b blocks) 7 Unknown Image 8 Unknown Image 9 Unknown Image 10 Type: SquashFS Data Size: 0x7212c bytes (0x391 blocks) 11 Unknown Image 12 Unknown Image 13 Unknown Image 14 Unknown Image 15 Unknown Image *** partition size changed *** *** create default partitions *** No. Type Status Start Size System ----------------------------------------------------------- 1 P 80 1 8000 16 MB Linux 2 P 00 8001 37c00 111 MB Empty 3 P 00 3fc01 400 512 KB Empty 4 E 00 40001 1bffff 895 MB Extended 5 L 00 40002 8000 16 MB Linux 6 L 00 48003 37c00 111 MB Empty 7 L 00 7fc04 400 512 KB Empty 8 L 00 80005 a0000 320 MB Empty 9 L 00 120006 2000 4 MB Empty 10 L 00 122007 2000 4 MB Empty 11 L 00 124008 2000 4 MB Empty 12 L 00 126009 2c1001 1 GB Linux 13 L 00 3e700b 17d79 47 MB Linux 14 L 00 3fed8b 3001 6 MB Linux 15 L 00 401d8d 12c001 600 MB Linux 1 Unknown Image 2 Unknown Image 3 Unknown Image 4 Unknown Image 5 Name: sh-linux Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 0x26c395 bytes (0x1362 blocks) Load Address: 80001000 Entry Point: 80002000 6 Type: SquashFS Data Size: 0x38d15f4 bytes (0x1c68b blocks) 7 Unknown Image 8 Unknown Image 9 Unknown Image 10 Type: SquashFS Data Size: 0x7212c bytes (0x391 blocks) 11 Unknown Image 12 Unknown Image 13 Unknown Image 14 Unknown Image 15 Unknown Image INFO: 06:687 Sync eMMC/SPI NOR/Alternate u-boot images FAIL: 00:129 U-boot 'ubootN1' on path N-1 failed CRC FAIL: 00:264 Verify OS Images N-1: Kernel crc exp=0x1139a4c6 rec=0xe36f2bd2 blk_start=0x40002 blk_size=0x1362 ENV bcnt=0x26c3d5 FAIL: 00:013 Boot device=emmc Boot partition5/N-1 Boot Path Retry:P1/N=3 P5/N-1=3 Recover INFO: 00:011 Sync eMMC/SPI NOR/Alternate u-boot images FAIL: 00:132 U-boot 'ubootN1' on path N-1 failed CRC FAIL: 00:265 Verify OS Images N-1: Kernel crc exp=0x1139a4c6 rec=0xf5896cb7 blk_start=0x40002 blk_size=0x1362 ENV bcnt=0x26c3d5 FAIL: 00:014 Boot device=emmc Boot partition5/N-1 Boot Path Retry:P1/N=3 P5/N-1=3 Recover INFO: 00:009 Autoboot will abort as Bootdelay = -1, Disable WDT2 INFO: 00:000 08:071 iDRAC7=>
rbf2501
September 9, 2021, 7:51pm
262
This thread serves as a useful warning to the uninitiated, but I’m not confident I understand the known proper/improper upgrade paths. If somebody is starting with a working but outdated 12th gen PowerEdge, what is the safest way to avoid all of this trouble (with no OS on server)? Is there an important difference between the “Platform-Specific Bootable ISO” versus the more generic Server Update Utility (SUU) if connected to internet?
@alexthefifth I looked at your logs again it it looks like when you make the SD card image its partitions are different than mine. There may be some differences between the R620 / R720 firmware that isn’t apparent here or there was something wrong with the TFTP load of the image. Hope you can figure it out.
Thank you so much for all your work @Darkendvoid Any chance you could post the "printenv" from your machine? No worries if not. I just want to compare mine to see where the difference might be
Hi. I’m very thankful for your guide. I carefully tried to follow it step by step on dell r520. i am using firmimg.d7 1.66v from dell website. Unfortunately after going carefully through all of it I get always message about creating deafult partitions. Here is my console output.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221
U-Boot 2009.08-00088-g121cddc (Nov 17 2014 - 05:50:46) Avocent (0.0.3) EVB, Build: jenkins-idrac-yocto-release-505 CPU: SH-4A BOARD: R0P7757LC00xxRL (C0 step) board BOOT: Secure, HRK not generated DRAM: 240MB (240MB of 256MB total DRAM is available on U-Boot) ENV: Using primary env area. In: serial Out: serial Err: serial WDT2: Booted Lower Vector, 'uboot1' sh_mmcif: 0, sh-sdhi: 1 Net: sh_eth.0, sh_g_eth.0 INFO: 00:003 Start-up -to- util_idrac_main() INFO: 00:004 U-Boot 2009.08-00088-g121cddc (Nov 17 2014 - 05:50:46) Avocent (0.0.3) EVB INFO: 00:008 U-Boot checkin date(05-10-2013) Version(1.0.183) INFO: 00:006 iDRAC PPID <NULL> INFO: 00:003 SPI NOR init 4096 KiB AT25DF321A bus=0 cs=0, speed=1000000, mode=3 INFO: 00:007 SH-4A Product: Major Ver=0x31 Minor Ver=0x14 C4 Little endian Family=0x10 Major Ver=0x30 Minor Ver=0x0b PASS: 00:016 Dedicated monolithic mgmt NIC disabled INFO: 00:128 BCM54610 OUI=0x3fffff Model=0x3f Revision=0x0f PhyAddr=1 INFO: 00:124 SD CARD: Device: sh-sdhi Manufacturer ID: 3 OEM: 5344 Name: SMI Tran Speed: 25000000 Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: -330301440 INFO: 00:058 EMMC: Device: sh_mmcif Manufacturer ID: 90 OEM: 14a Name: HYNIX Tran Speed: 25000000 Rd Block Len: 512 MMC version 4.0 High Capacity: Yes Capacity: 0 INFO: 00:018 CPLD: Major Ver=0x1 Minor Ver=0x0 Maint Ver=0x4 Planar: Type=0x0a Rev=0x4 Rework=0x0 Scratch/PathRetry=0x0f PASS: 00:014 Coin cell detected good, AD=0x3ab low water=0x2c1 PASS: 00:008 PCIe C0 Ver=0.15 MCTP en, CRC=0x8e9b6875 @0x8efbf954 cnt=0x18000 INFO: 00:007 Init PCIe mailbox(PCIe 0xFFEE0150=0x40010000) INFO: 00:006 mode=normal INFO: 00:002 reset_cause=recover PASS: 00:005 Booted Lower Vector, 'uboot1' wdt2cnt=0 INFO: 00:005 wdt0cnt=4 PASS: 00:002 SMR0 no sermux env, default 0xd4 INFO: 00:005 GRACR=0x3c HISEL=0x00 SIRQCR5_D=0x03 SIRQCR6_D=0x01 LADMSK0=0xff2 MRSTCR0=0xfedffe7f MRSTCR1=0xfff3ff0f MRSTCR2=0x7f80feff BARMAP=0x1 BCR=0x85000000 NCER=0x01fc NCMCR=0x0006 NCCSR=0x0303 PASS: 00:021 etherc0=F0:1F:AF:E1:27:42 getherc0=F0:1F:AF:E1:27:43 INFO: 00:007 Fan logic is not modified on Non-AC power up INFO: 00:052 Env and backup CRC'ed ok Extended partiton size is 0x1bffff Clear beginning MASER, start_blk=0x126009 blk_cnt=0x7000 *** create default partitions *** No. Type Status Start Size System ----------------------------------------------------------- 1 P 80 1 8000 16 MB Linux 2 P 00 8001 37c00 111 MB Empty 3 P 00 3fc01 400 512 KB Empty 4 E 00 40001 1bffff 895 MB Extended 5 L 00 40002 8000 16 MB Linux 6 L 00 48003 37c00 111 MB Empty 7 L 00 7fc04 400 512 KB Empty 8 L 00 80005 a0000 320 MB Empty 9 L 00 120006 2000 4 MB Empty 10 L 00 122007 2000 4 MB Empty 11 L 00 124008 2000 4 MB Empty 12 L 00 126009 2c1001 1 GB Linux 13 L 00 3e700b 17d79 47 MB Linux 14 L 00 3fed8b 3001 6 MB Linux 15 L 00 401d8d 12c001 600 MB Linux 1 Name: sh-linux Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 0x26d595 bytes (0x136b blocks) Load Address: 80001000 Entry Point: 80002000 2 Type: SquashFS Data Size: 0x38ebadc bytes (0x1c75e blocks) 3 Unknown Image 4 Unknown Image 5 Name: sh-linux Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 0x26d595 bytes (0x136b blocks) Load Address: 80001000 Entry Point: 80002000 6 Type: SquashFS Data Size: 0x38ebadc bytes (0x1c75e blocks) 7 Unknown Image 8 Unknown Image 9 Type: SquashFS Data Size: 0x72717 bytes (0x394 blocks) 10 Type: SquashFS Data Size: 0x72717 bytes (0x394 blocks) 11 Unknown Image 12 Unknown Image 13 Unknown Image 14 Unknown Image 15 Unknown Image *** partition size changed *** *** create default partitions *** No. Type Status Start Size System ----------------------------------------------------------- 1 P 80 1 8000 16 MB Linux 2 P 00 8001 37c00 111 MB Empty 3 P 00 3fc01 400 512 KB Empty 4 E 00 40001 1bffff 895 MB Extended 5 L 00 40002 8000 16 MB Linux 6 L 00 48003 37c00 111 MB Empty 7 L 00 7fc04 400 512 KB Empty 8 L 00 80005 a0000 320 MB Empty 9 L 00 120006 2000 4 MB Empty 10 L 00 122007 2000 4 MB Empty 11 L 00 124008 2000 4 MB Empty 12 L 00 126009 2c1001 1 GB Linux 13 L 00 3e700b 17d79 47 MB Linux 14 L 00 3fed8b 3001 6 MB Linux 15 L 00 401d8d 12c001 600 MB Linux 1 Name: sh-linux Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 0x26d595 bytes (0x136b blocks) Load Address: 80001000 Entry Point: 80002000 2 Type: SquashFS Data Size: 0x38ebadc bytes (0x1c75e blocks) 3 Unknown Image 4 Unknown Image 5 Name: sh-linux Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 0x26d595 bytes (0x136b blocks) Load Address: 80001000 Entry Point: 80002000 6 Type: SquashFS Data Size: 0x38ebadc bytes (0x1c75e blocks) 7 Unknown Image 8 Unknown Image 9 Type: SquashFS Data Size: 0x72717 bytes (0x394 blocks) 10 Type: SquashFS Data Size: 0x72717 bytes (0x394 blocks) 11 Unknown Image 12 Unknown Image 13 Unknown Image 14 Unknown Image 15 Unknown Image INFO: 08:831 Sync eMMC/SPI NOR/Alternate u-boot images PASS: 00:075 Current u-boot1 1.0.183 verified with 'ubootN' Trailer Struct - Missing start token, exp=0xc0de1111 rec=0x0 FAIL: 00:213 Verify OS Images N: Kernel crc exp=0x8c86b2b rec=0xa0cef433 blk_start=0x1 blk_size=0x136b ENV bcnt=0x26d5d5 FAIL: 00:013 Boot device=emmc Boot partition1/N Boot Path Retry:P1/N=3 P5/N-1=3 Recover INFO: 00:011 Sync eMMC/SPI NOR/Alternate u-boot images PASS: 00:074 Current u-boot1 1.0.183 verified with 'ubootN' Trailer Struct - Missing start token, exp=0xc0de1111 rec=0x0 FAIL: 00:213 Verify OS Images N: Kernel crc exp=0x8c86b2b rec=0xa0cef433 blk_start=0x1 blk_size=0x136b ENV bcnt=0x26d5d5 FAIL: 00:013 Boot device=emmc Boot partition1/N Boot Path Retry:P1/N=3 P5/N-1=3 Recover INFO: 00:000 09:961 WDT2: Disabled ###################################################################### ** No bootable iDRAC image is found ** ** (System Health & ID LED is flashing amber at ~1/2 second rate). To Recover iDRAC via an SD card. 1) Format SD using FAT on a Windows box or EXT3 using Linux. 2) Copy 'firmimg.d7' to root path. 3) Insert SD card. 4) System Health & ID button solid amber durning recover. 5) Both boot paths are flashed. ###################################################################### Polling for SD card state change \ SD card state change, previous=0x7a0 new=0x788 ###################################################################### ** No bootable iDRAC image is found ** ** (System Health & ID LED is flashing amber at ~1/2 second rate). To Recover iDRAC via an SD card. 1) Format SD using FAT on a Windows box or EXT3 using Linux. 2) Copy 'firmimg.d7' to root path. 3) Insert SD card. 4) System Health & ID button solid amber durning recover. 5) Both boot paths are flashed. ###################################################################### Polling for SD card state change -
And this is output after restarting server with changed mmcblk0 to mmcblk1.
U-Boot 2009.08-00088-g121cddc (Nov 17 2014 - 05:50:46) Avocent (0.0.3) EVB, Build: jenkins-idrac-yocto-release-505 CPU: SH-4A BOARD: R0P7757LC00xxRL (C0 step) board BOOT: Secure, HRK not generated DRAM: 240MB (240MB of 256MB total DRAM is available on U-Boot) ENV: Using primary env area. In: serial Out: serial Err: serial PCIe: Bridge loaded with 0x18000 bytes WDT2: Booted Lower Vector, 'uboot1' sh_mmcif: 0, sh-sdhi: 1 Net: sh_eth.0, sh_g_eth.0 INFO: 00:002 Start-up -to- util_idrac_main() INFO: 00:005 U-Boot 2009.08-00088-g121cddc (Nov 17 2014 - 05:50:46) Avocent (0.0.3) EVB INFO: 00:008 U-Boot checkin date(05-10-2013) Version(1.0.183) INFO: 00:006 iDRAC PPID <NULL> INFO: 00:003 SPI NOR init 4096 KiB AT25DF321A bus=0 cs=0, speed=1000000, mode=3 INFO: 00:007 SH-4A Product: Major Ver=0x31 Minor Ver=0x14 C4 Little endian Family=0x10 Major Ver=0x30 Minor Ver=0x0b PASS: 00:016 Dedicated monolithic mgmt NIC disabled INFO: 00:128 BCM54610 OUI=0x3fffff Model=0x3f Revision=0x0f PhyAddr=1 INFO: 00:192 SD CARD: Device: sh-sdhi Manufacturer ID: 3 OEM: 5344 Name: SMI Tran Speed: 25000000 Rd Block Len: 512 SD version 2.0 High Capacity: Yes Capacity: -330301440 INFO: 00:496 EMMC: Device: sh_mmcif Manufacturer ID: 90 OEM: 14a Name: HYNIX Tran Speed: 25000000 Rd Block Len: 512 MMC version 4.0 High Capacity: Yes Capacity: 0 INFO: 00:019 CPLD: Major Ver=0x1 Minor Ver=0x0 Maint Ver=0x4 Planar: Type=0x0a Rev=0x4 Rework=0x0 Scratch/PathRetry=0x00 PASS: 00:013 Coin cell detected good, AD=0x3ac low water=0x2c1 PASS: 00:008 PCIe C0 Ver=0.15 MCTP en, CRC=0x8e9b6875 @0x8efbf954 cnt=0x18000 INFO: 00:007 Init PCIe mailbox(PCIe 0xFFEE0150=0x40010000) INFO: 00:006 mode=normal Erasing SPI flash at 0x100000...Writing to SPI flash...done Erasing SPI flash at 0x110000...Writing to SPI flash...done PASS: 01:155 Booted Lower Vector, 'uboot1' wdt2cnt=0 INFO: 00:005 wdt0cnt=4 PASS: 00:003 Clear CH1/CH2, clear 4K shared memory@0xffcaa000 on AC power up PASS: 00:007 SMR0 no sermux env, default 0xd4 INFO: 00:005 GRACR=0x3c HISEL=0x00 SIRQCR5_D=0x03 SIRQCR6_D=0x01 LADMSK0=0xff2 MRSTCR0=0xfedffe7f MRSTCR1=0xfff3ff0f MRSTCR2=0x7f80feff BARMAP=0x1 BCR=0x85000000 NCER=0x01fc NCMCR=0x0006 NCCSR=0x0303 PASS: 00:021 etherc0=F0:1F:AF:E1:27:42 getherc0=F0:1F:AF:E1:27:43 INFO: 00:009 Fan logic for monolithic planar type 10 fan1 - def 0000 1fff 3d fan2 - def 0000 1fff 3d fan3 - def 0000 1fff 3d fan4 - def 0000 1fff 3d fan5 - def 0000 1fff 3d fan6 - def 0000 1fff 3d fan7 - def 0000 1fff 3d fan8 - def 0000 1fff 3d INFO: 00:077 Env and backup CRC'ed ok Extended partiton size is 0x1bffff Clear beginning MASER, start_blk=0x126009 blk_cnt=0x7000 *** create default partitions *** No. Type Status Start Size System ----------------------------------------------------------- 1 P 80 1 8000 16 MB Linux 2 P 00 8001 37c00 111 MB Empty 3 P 00 3fc01 400 512 KB Empty 4 E 00 40001 1bffff 895 MB Extended 5 L 00 40002 8000 16 MB Linux 6 L 00 48003 37c00 111 MB Empty 7 L 00 7fc04 400 512 KB Empty 8 L 00 80005 a0000 320 MB Empty 9 L 00 120006 2000 4 MB Empty 10 L 00 122007 2000 4 MB Empty 11 L 00 124008 2000 4 MB Empty 12 L 00 126009 2c1001 1 GB Linux 13 L 00 3e700b 17d79 47 MB Linux 14 L 00 3fed8b 3001 6 MB Linux 15 L 00 401d8d 12c001 600 MB Linux 1 Name: sh-linux Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 0x26d595 bytes (0x136b blocks) Load Address: 80001000 Entry Point: 80002000 2 Type: SquashFS Data Size: 0x395c6ce bytes (0x1cae4 blocks) 3 Unknown Image 4 Unknown Image 5 Name: sh-linux Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 0x26d595 bytes (0x136b blocks) Load Address: 80001000 Entry Point: 80002000 6 Type: SquashFS Data Size: 0x395c6ce bytes (0x1cae4 blocks) 7 Unknown Image 8 Unknown Image 9 Type: SquashFS Data Size: 0x72717 bytes (0x394 blocks) 10 Type: SquashFS Data Size: 0x72717 bytes (0x394 blocks) 11 Unknown Image 12 Unknown Image 13 Unknown Image 14 Unknown Image 15 Unknown Image *** partition size changed *** *** create default partitions *** No. Type Status Start Size System ----------------------------------------------------------- 1 P 80 1 8000 16 MB Linux 2 P 00 8001 37c00 111 MB Empty 3 P 00 3fc01 400 512 KB Empty 4 E 00 40001 1bffff 895 MB Extended 5 L 00 40002 8000 16 MB Linux 6 L 00 48003 37c00 111 MB Empty 7 L 00 7fc04 400 512 KB Empty 8 L 00 80005 a0000 320 MB Empty 9 L 00 120006 2000 4 MB Empty 10 L 00 122007 2000 4 MB Empty 11 L 00 124008 2000 4 MB Empty 12 L 00 126009 2c1001 1 GB Linux 13 L 00 3e700b 17d79 47 MB Linux 14 L 00 3fed8b 3001 6 MB Linux 15 L 00 401d8d 12c001 600 MB Linux 1 Name: sh-linux Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 0x26d595 bytes (0x136b blocks) Load Address: 80001000 Entry Point: 80002000 2 Type: SquashFS Data Size: 0x395c6ce bytes (0x1cae4 blocks) 3 Unknown Image 4 Unknown Image 5 Name: sh-linux Type: SuperH Linux Kernel Image (gzip compressed) Data Size: 0x26d595 bytes (0x136b blocks) Load Address: 80001000 Entry Point: 80002000 6 Type: SquashFS Data Size: 0x395c6ce bytes (0x1cae4 blocks) 7 Unknown Image 8 Unknown Image 9 Type: SquashFS Data Size: 0x72717 bytes (0x394 blocks) 10 Type: SquashFS Data Size: 0x72717 bytes (0x394 blocks) 11 Unknown Image 12 Unknown Image 13 Unknown Image 14 Unknown Image 15 Unknown Image INFO: 09:993 Sync eMMC/SPI NOR/Alternate u-boot images PASS: 00:258 Current u-boot1 1.0.183 verified with 'ubootN' Trailer Struct - Missing start token, exp=0xc0de1111 rec=0x0 U-boot2 in sync with u-boot1 1.0.183 FAIL: 00:217 Verify OS Images N: Kernel crc exp=0x8c86b2b rec=0xa0cef433 blk_start=0x1 blk_size=0x136b ENV bcnt=0x26d5d5 PASS: 00:222 Boot device=emmc Boot partition5/N-1 Boot Path Retry:P1/N=3 P5/N-1=0 swapping to P5/N-1 INFO: 00:012 Sync eMMC/SPI NOR/Alternate u-boot images PASS: 00:259 Current u-boot1 1.0.183 verified with 'ubootN1' Trailer Struct - Missing start token, exp=0xc0de1111 rec=0x0 U-boot2 in sync with u-boot1 1.0.183 FAIL: 01:075 Verify OS Images N-1: Kernel crc exp=0x8c86b2b rec=0xc497e447 blk_start=0x40002 blk_size=0x136b ENV bcnt=0x26d5d5 FAIL: 00:013 Boot device=emmc Boot partition5/N-1 Boot Path Retry:P1/N=3 P5/N-1=3 P5/N-1 now expired INFO: 00:000 14:258 WDT2: Disabled ###################################################################### ** No bootable iDRAC image is found ** ** (System Health & ID LED is flashing amber at ~1/2 second rate). To Recover iDRAC via an SD card. 1) Format SD using FAT on a Windows box or EXT3 using Linux. 2) Copy 'firmimg.d7' to root path. 3) Insert SD card. 4) System Health & ID button solid amber durning recover. 5) Both boot paths are flashed. ###################################################################### Polling for SD card state change -
So close yet so far.
Im stuck here and i would be realy greatful for some advice.
Hi, it appears that I’ve bricked my iDrac as well after attempting to upgrade the firmware. I’ve been going through this thread, how can I connect via UART, can this only be done using a Rasberry PI?
natharas:
You can just use a "UART to USB converter" cable. They go for around $15 on amazon, and around $5 on ebay
Hello, I have a Dell T320 that is showing the following error: "SWC0700: iDRAC is not ready. The configuration cannot be accessed." I’ve read the entire thread and I want to debug idrac but I can’t find the iDRAC_UART pins on the mainboard Can someone help me?
rgrimes
October 9, 2021, 3:41am
269
@Rob.vicz I have no idea, never looked at a t320, but as a "hint" the idrac uart port should be near the SH_4A cpu chip that runs the idrac code. So if you can find the SH_4A you have a better chance of locating the other stuff. This is marked SH77572, about 1" square BGA package, usually has a board white silk screen next to it "iDrac".
alexthefifth:
Zitat von natharas im Beitrag #266 Hi, it appears that I've bricked my iDrac as well after attempting to upgrade the firmware. I've been going through this thread, how can I connect via UART, can this only be done using a Rasberry PI?
Thank you, has anyone taken photos of their soldering? Did you just solder the wires to the UART on the mobo?
rgrimes:
https:/ /imgur.*com/a/S7ECRoP The pin pads I found is next to "SUPERVU_Debug" but there is no mention of idrac.
Hi all, I ran into the same issue with my dell T620. I found similair EMMC pads, and the ground pins also where in similair positions: ht*tps://cdn.*discordapp.com/attachments/6…keAf6Lq9YHV.png I have two motherboards, one died with an issue on the power rail so I soldered wires to that one to no avail. Then I made a pogo pin array, as I did not trust my soldering: https://media.*discordapp.net/attachments…=507&height=676 I am sure this one worked, but to no avail aswell… I do have connectors called BMC Jtag, though I have no clue which one it points too: https://media.*discordapp.net/attachments…=901&height=676 And I have a connector called BMC Uart at the corner of the board: https://media.*discordapp.*net/attachments…=507&height=676 Now where to start… All photos in links you can do something with:
1 2 3 4 5
ht*tps://cdn.*discordapp.*com/attachments/675090184135508028/897990322834006096/FIcCUnd65eDQ0IVKL8H_HzFJQRUoXbyUBZM4Hpy1tSb4laeiuWauHSnhf4ZDf1fGhdTIrYOB_xxPbon5uPJig19bMkeAf6Lq9YHV.png ht*tps://media.*discordapp.*net/attachments/101728343254114304/897893011990646804/unknown.png?width=507&height=676 ht*tps://media.*discordapp.*net/attachments/675090184135508028/897991731339989084/IMG_20211014_013529.jpg?width=901&height=676 ht*tps://media.*discordapp.*net/attachments/675090184135508028/897991753506881546/IMG_20211014_013714.jpg?width=507&height=676
@Don_prince I can’t see much in your photos, they are too low resolution, “BMC UART” is mostly likely the correct one Here’s where the UART is on my T620: https://i.imgur.com/yREu9Qx.jpg I decided not to solder and just use an elastic band to apply pressure to the pins lol and a binder clip to hold the USB->UART cable in place, here’s a closeup:https://i.imgur.com/Vfe6Ic7.jpg https://i.imgur.com/5HaXkZU.png
@alexthefifth that was one of the ones I identified, Do we also have to do the Uboot interupt? I guess we would need to use the SPI DBG pins for that? Where did you get your pogo pin thing? I could 3d print another one, but mine get rather bulky due to the resolution of the printer
I do believe I had to interrupt Uboot by using the SPI DBG pins yes My pogo pin thing is just 4 of these male “dupont” header/jumper cables taped together to make a rigid structure: https://cdn.shopify.com/s/files/1/2396/0…PG?v=1506712477 something like: https://www.aliexpress.com/item/32891879…781440307%22%7D These 4-pin “RGB” connectors would probably also work well and no need for tape: https://www.pcboard.ca/image/cache/catal…r-3-600x315.jpg
I saw the prices of one and 3d printed another one. I still have loads of pogo pins left…
1
ht*tps://cdn.*discordapp.*com/attachments/101728343254114304/898249143544320090/unknown.png
I have a usb uart/ttl thing on its way so I should be good to try it tomorrow.
Pinout is:
Square one (no idea) dont connect????
RX
TX
GND
Correct?
Only 3 of the 4 need to be connected, yes. Not sure which one is RX/TX, I usually experiment swapping back and forth until something appears on screen
well, I got a result: ht"tps://media."discordapp."net/attachments/101728343254114304/898697197804204062/unknown.png Proud of that, but can’t make heads or tails from it. I tried baudrate 9600 and 11500 but the result was the same weird things… N▒▒▒▒▒ɠ▒͇▒▒▒▒▒▒’p▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒.▒▒▒▒▒▒▒▒▒▒▒▒g▒▒ɇ▒s▒Ȁӫ▒·▒▒▒▒▒▒ȇ▒▒▒▒Nx▒▒▒▒▒▒▒▒▒▒▒▒▒▒·▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒h▒▒▒▒▒▒▒▒▒▒▒▒▒ȧG▒Δ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
need to correct myself – on my T620 the pad name is not SPI DBG – it is "SW7" (on other PowerEdge models it is apparently "SW2"), and the pin to interrupt uboot is SW7-2-1 (need to ground it before powering on the server) picture here: https://i.imgur.com/TAwKepQ.jpg
