Hi everyone,
I’m encountering reproducible, counter-intuitive behavior on an LGA 1150 platform and would appreciate low-level architectural or BIOS-level insight.
Platform Specifications:
Motherboard: Gigabyte GA-Z87-HD3 (BIOS: F8, AMI Aptio IV UEFI)
CPU: Intel Core i5-4670 (Haswell, 4C/4T, stock clocks)
RAM: 2x8GB DDR3 1600MHz (Dual Channel, JEDEC timings)
dGPU: Gigabyte AORUS Radeon RX 580 8GB (PCIe 3.0 x16, Primary Display Output set to PCIe 1 Slot)
OS: Windows 10 x64 21H2/22H2 (Native UEFI / GPT mode, CSM disabled)
Observed Behavior:
Baseline (iGPU Enabled):
In BIOS:
Intel Processor Graphics -> Enabled(DVMT 64M/MAX), official Intel HD 4600 driver installed. Display cable plugged directly into RX 580.Result: Games (e.g. Counter-Strike 2, DX11/Vulkan titles) run consistently at ~160–180 FPS. System and CPU frame pacing are smooth.
iGPU Disabled + Cleaned (Performance Degradation):
In BIOS:
Intel Processor Graphics -> Disabled. In Windows: wiped Intel display driver via DDU / clean state.Result: Frame rates immediately plummet across all titles by 30–40% (CS2 drops to 100–120 FPS), with noticeably spikier CPU frame times.
The Driver Quirk:
If
Intel Processor Graphicsis set toDisabledin BIOS, but the Intel driver stack/registry entries remain untouched in Windows without cleaning, the framerate penalty is significantly less severe or unnoticeable.
Re-enabling the iGPU in BIOS and loading the Intel display driver immediately restores full dGPU performance.
Technical Inquiries:
Haswell FIVR / Power Domain Interaction:
When the GT (Graphics) power plane is shut down via BIOS strapping/registers, does the integrated voltage regulator (FIVR) on Haswell alter Ring Bus (Uncore) frequency governors, current limit thresholds (PL1/PL2 / Package C-states), or thermal throttling behavior on older stepping Haswell dies?
Gigabyte Aptio DSDT / ACPI Table Implementation:
Is this a known BIOS bug where Gigabyte’s DSDT code incorrectly handles PEG link parameters or interrupt routing when the integrated graphics device (
_SB.PCI0.GFX0) is hidden? -
WDDM / DWM Context Switching:
Could this be attributed to Windows DWM scheduling overhead forcing single-adapter context switching on the Polaris driver, which becomes CPU-bound on a pure 4-thread processor without QuickSync/iGPU offloading desktop composition?
Has anyone analyzed this in UEFI modules or monitored MSR / FIVR registers under these conditions?
Thanks in advance for any insights!
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized/shortened
