[Problem] Faulty MSI PRO Z790-A MAX WIFI (MS-7E07) BIOS
I was having claude help me with this issue but im so stumped so i asked it to summarize everything since it obv will do a better job explaining it than me.
My MSI PRO Z790-A MAX WIFI (MS-7E07) has incorrect SMBIOS/DMI values and I cannot get them to write no matter what I try. The values I need written are:
  • Manufacturer: Micro-Star International Co., Ltd.
  • Product: PRO Z790-A MAX WIFI (MS-7E07)
  • Serial:
Everything I’ve tried:
First I tried AMIDEWINx64 in Windows from an admin command prompt and got: 10 - Error: Unable to load driver
Tried the usual fixes — disabled driver signature enforcement, enabled test signing via bcdedit, ran as administrator. Nothing worked.
Interesting thing I noticed — I have a DMA device and when I unplugged it, AMIDEWINx64 actually ran and appeared successful, even asking for admin permissions like normal. But after a reboot the values were still wrong, so it seems like it was only writing to the live memory table and not actually committing to flash.
So I made a bootable UEFI shell USB and tried AMIDEEFIx64 to bypass Windows entirely. Same result every single time regardless of which field I tried to write:
Initializing the SMBIOS interface. Please wait......
Error: Fail to initialize SMBIOS.
d9 - Error: DMI Data write failed.
After that I tried:
  • Disabling Secure Boot in BIOS — no change
  • Disabling CFG Lock — no change
  • Downgrading BIOS from M91 to M70 thinking the write lock might have been added in a later version — same errors on M70
  • Fresh Windows install — incorrect values still there, confirming it’s baked into the firmware and not an OS caching issue
Contacted MSI support with full documentation and photos of the errors and they basically said it’s not something they can help with.
Where I’m at:
At this point it’s pretty clear the SMBIOS region is write protected at the chipset/SPI level and none of the standard tools can touch it. I’m on BIOS version M70 right now because I was trying to fix it but prefer to run 7E07vM91.
What I’m hoping someone can help with is either:
  • A modded BIOS for the MS-7E07 with the correct SMBIOS values baked in, or
  • A modded BIOS with the write protection stripped so I can write the values myself with AMIDEWIN
I’d rather not go the CH341A route and physically clip onto the SPI chip unless there’s absolutely no other option, but I’m not ruling it out either.
Has anyone dealt with write protection on a Z790 MSI board before? Any help is massively appreciated.
Board: MSI PRO Z790-A MAX WIFI (MS-7E07) Current BIOS: M70 OS: Windows 11 (Build 10.0.26200.8457)
Edit by Fernando: Thread title customized and shortened
Have you try to disable everything in Core Isolation? Disable all of these:
And then reboot, then check again if it’s enabled or disabled. If you need extra steps after all of these are disabled and still not working, you can download dgreadiness tool, use extract here option as it is contained in a folder, run powershell as admin, type Set-ExecutionPolicy unrestricted and enter, press A and enter, exit powershell and re open powershell as admin, change directory to the dgreadiness folder (for example, type cd "D:\Downloads\dgreadiness_v3.6" and enter), and after powershell enter the dgreadiness folder, type .\DG_Readiness_Tool_v3.6.ps1 -disable and enter, then reboot and spam F3 key. When the bios logo appears, keep spamming, it will prompt to disable device guard, and after you keep spamming, a 2nd reboot will occurs, and you can release the F3 spam.
Get a clean extract from AMIDEWINX64 just to make sure the drivers included in the folder is not missing. Or you can google up DMIEdit v5.27.05.0016, and download it. It should consists of these:
