[Problem] Flashing a mod vBIOS for NVIDIA GTX 970M 3GB
Hello everyone, I have Clevo P670SE laptop with modded BIOS v1.05.01. I want to flash my custom-made VBIOS for GTX 970M 3GB. I did backups of VBIOS (G204.rom, 109KB in size) via GPU-Z succesfully and modified it with Maxwell II BIOS Tweaker, after which it changed checksum from 8E to 70 (green, so that means its valid, I guess). Then I tried to flash it via NVFlash (Bypass Certificates version), but with no success, whatever commands I have done. I still didnt try in FreeDOS environment though, so thats my only option that remains, but frankly I dont think it will work for whatever reason, but will try it when I have time. I also tried to flash it with CH341B programmer (with correct voltage of 3.3V), but as soon as I tried to click DETECT in NeoProgrammer, it crashes instantly, same with AsProgrammer. I know that drivers and programmer with SOIC8 clam work, because after that I tried to read my main BIOS chips (25Q32/64BSIG) and it read and verified them flawlessly. Also I have cut the “VCC PIN8” on SOIC8 clam to prevent CH341 to power up whole mobo instead of chip only, then plugged in the charger, tried that way but still the same, crash. The main problem probably is that my laptop doesnt have “MUX-ed” option in Switchable Graphics option, only “MUXless”, but it has DX 5.0 option that has “BAC0 Mode” and “dGPU Off” (altho its for AMD GPUs), I have tried those options but still the same in NVFlash. I also tried to make my GTX 970M slightly under load to “wake it up” maybe so that Windows and NVFlash can detect it (otherwise its “No display adapter found” message) and it did unlocked write permission with --protectoff command, but after applying with “Y” two times, it fails with the message that access of EEPROM is denied somehow. Does anyone know whats happening here and how can I flash my modded VBIOS? Sorry for my bad english and long post. Best regards!
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
