I am trying to flash my bios using a CH314A Programmer. I am unable to find where the chip actually is.
I thought I knew which one it was when I found GD25B256E. However I havent been able to read at it from all
Then I found a chip clearly labeled BIOS. However that chip is labeled A1 13 15 A0 2307 which doesn’t match any bios chip I know. What do I do.
Main bios IC its WSON8 package IC and needs to be desoldered or connected with a POGO needle pin, not the standard SOIC8 that comes in “common” CH341A programmers.
Do check the dump content for complete Bio’s image and respective ME FW image, if not all in the same IC then it may have another.
Okay so based off the location of ours and the surrounding chips it would be the GD25B256E. Thanks, and yeah Im having a hard time using the SOIC8 on it
