[Problem] GA-H67MA-USB3-B3 with NVIDIA Tesla V100 GPU
Hi,
I’m trying to run an NVIDIA Tesla V100 on a Gigabyte GA-H67MA-USB3-B3 (Sandy Bridge / H67, Award BIOS, latest F8) and I’m hitting a classic resource problem at POST, before any OS loads.
Hardware & goal
Motherboard: GA-H67MA-USB3-B3 (rev 1.0)
BIOS: Award, F8
GPU: Tesla V100 (large 64-bit prefetchable BAR, ~16–32 GB)
Goal: get the card to POST without breaking storage/USB so the system can actually boot
What happens
With the V100 installed:
Disk is not detected / “disk not found”
USB devices stop working
Failure is before the OS — so OS-level workarounds (DSDT, drivers, etc.) don’t help
This looks like PCI MMIO / BAR resource exhaustion: the BIOS’s 32-bit-only allocator can’t place the V100’s huge BAR, and SATA/USB lose their windows.
Control test (working system)
The same Tesla V100 works on an ASUS P8H61-M LE when Memory Remap Feature is enabled.
So the card itself is fine; the difference is firmware behavior (AMI on ASUS vs Award on Gigabyte).
What I already checked in the Gigabyte BIOS
I dumped and inspected official F8 (including decompressed modules):
No setup option for:
Above 4G Decoding
Memory Hole Remap
anything like 64-bit MMIO / large BAR
“64-bit mode” in setup is HPET only, not PCI
MRC does contain internal strings:
Remap Base / Remap Limit
Reclaim Enable / Reclaim disable
so RAM reclaim above 4G exists internally, but there is no user toggle and no evidence of a full 64-bit PCI BAR allocator path
Live menus match the manual: M.I.T., Standard CMOS, Advanced BIOS Features, Integrated Peripherals, etc. — no Advanced Chipset “remap” item
So this is not “hidden option in CMOS.” The PCI resource path looks stuck in a below-4G / 32-bit model.
Core question
On Award 6.xx for H67 (this board specifically):
Has anyone successfully modded Award to support 64-bit MMIO / large BARs (Above 4G-style behavior)?
Where does PCI resource allocation typically live in these images (module / stage), and is it realistic to extend it without rewriting half of POST?
Or is this effectively a dead end for huge-BAR devices like Tesla V100, and the practical answer is “use a board whose BIOS already has the path” (like the ASUS)?
I’m not asking anyone to do a full reverse for free — I want hard experience: known patches, known failures, or “don’t bother, Award never grew this path on 6-series.”
What would help
Links to any Award 6/7-series work on 64-bit BAR / above-4G-like behavior
Pointers to which modules usually own PCI resource assignment on Gigabyte Award
Confirmation if MRC reclaim alone is insufficient without a 64-bit PCI enumerator (which is my current understanding)
Brutally honest “change the board” if that’s the consensus
Board + BIOS are old; I’m fine hearing that this is not worth the brick risk. I just want to close the “maybe we can rewrite 32→64 in the allocator” question with real firmware experience, not theory.Thanks.
Edit by Fernando: Thread title customized and shortened
