My board is a gigabyte z390 master rev 1.0. My Bios switches are main and single bios.
I was using for sometime bios f11o modified, but thought its been years so contacted gigabyte for a newer bios with added RGB they gave me f13c. All seemed fine untill they offered me a update, and I got oem id mismatch, with all bios they offered.
Now before when on f11o I was warned about getting the newer, due to being capsule, but as it’s been some time i thought others may have sorted this by now, but not sure how or whats the best and safest way.
On my backup bios I have f10 I tried switching to the back then entering qflash and alt f10 but on save and exit the system hangs and the backup is not copied to the main. Due to main being capsule I guess?
Will a moddied efiflash work, if so what version?
Also looked at and was pointed to fpt flashing tool, but again not sure where to start, and dont want to lose my network or I can return the board to gigabyte who will do a bios refresh?
A Update. My bios issue has been sorted, I’m now looking to make changes to the bios.
So your saying efiflash will work with capsule bios, what version of efiflash should I use, I see many on there, I guessing DOS version, and use rfus to make a bookable usb?
There are many enthusiasts on this forum.
This is an old system and no one needs it.
If you asked for advice, then you have assessed all the risk factors.
In my opinion - it should work perfectly.
if there are doubts about the BIOS firmware - use the CH341 programmer
By the way, your system will only work with coffee and no mutagens.
Thanks so much for the replys, guess it’s down to trial and error now, if all fails gigabyte will RMA, its just as you say Its old and delivery services are not the best.
Not got time till next week to see what I can do.
Was hoping someone with my board may have more advice
Thanks again Zaver
P.s Gigabyte has said there RMA my board, I’m still waiting on a reply as I said it’s affected 100s of people, as I had shared it
I do think changing the bit mentioned by @Zaver able to bypass the oem mismatch, i also remember that i once flashed a Z390 UD with intel fpt easily, so you might want to back up the current bios with intel fpt from csme system tools v12, find the nvram values and the paddings, and see if it implements a motherbioard specific config, or just send the dump here/via transfer.it if you’re not sure.
Assuming you did update the modded bios F11 from stock bios when you have the board using qflash only, One thing i thought of was:
Dump the current bios
Download official F11 bios
Using UEFITool NE latest ver, extract Nvram vol, FD44 partition if available
Using intel FIT v12, open the dump bios file (rename it to .bin if it wasn’t .bin) and then save as the .xml and exit the FITv12
open the folder named the same as your dump, Copy the GBE Region and the OEM partition if available, paste it somewhere else, you can savely delete the folder, the dump bios, and the .xml
Now back to the F11 stock downloaded bios, replace the nvram .vol using uefitool v0.25.0, and then replace the fd44 if available, and save that bios.
Rename that edited F11 bios to .bin, open that edited F11 bios in intel fit, go to build settings and set generate intermediate file to no, and then save as .xml and close the app, copy the GBE Region and OEM Partition (if available) that you copied earlier, then open the folder named the same as the f11 bios name and go to decomp, and paste the GBE Region aswell the OEM Partition if available. go back to main folder, open the fit app again, and load the saved .xml earlier in the intel fit app, and build image.
Now it will output “outputimage.bin”, use that file with intel fpt, the args should be -rewrite -f outputimage.bin (if fpt is named fptw64, then just type fptw64 -rewrite -f outputimage.bin).
That’s way over my head and i’m on the f13 capsule bios, I updated using the Qflash in bios. my backup bios is F10. I have been told to use FPT and make sure to do the save mac and I should not have a problem. yet it to hot to try anything at the moment. will wait till it cools down in the uk.
Probably, but the you just gotta see if there is any board specific IDs in the bios structure other than mac address (Gbe Region) and SMBiosFlashData, it could be in the padding, or the nvram itself.
Hello!
Everything works excelent for me on Z370PD3 with modified firmware code, network - Realtek/
Any BIOS can be flashed using Q-Flash
I thought this question would somehow help @trebleta
Thank you.
I haven’t had time to try yet, been away. Gigabyte want me to try, booting in to my backup bios with the switched and single bios, then switch to main bios and try flashing.
I can share the bios. I have so many, my backup is F10, the lastest I have is F13f. The one oem custom locked that gigabyte can’t fix is F13c that is the main bios.
I have every version from F9 Inc beta to f11o before capsule. Then f13a-f.
My plan is to try what gigabyte have asked, flashing back to F10, then if it works i will flash to f13a then f13f.
What versions do you want me to share the f13c that is oem custom locked?
Thanks all for the advice, its well appreciated
P.s I haven’t used any flashing tools for 2-3 years I quite good at dos commands etc just last time I did hex modding I distroyed the sata controller so scared I’d mess up.
@trebleta You can share the bios that eSupport sent you as-is, and the full main bios chip dump that hasn’t been tampered by flashing with other tool like efiflash or intel fpt, as in the bios mod you did flash previously was with qflash. To dump, use intel fpt from csme system tools v12 shared in this forum (commands is fptw64 -d backup.rom) if you haven’t backed it up yet.
If size too big to share here, you can use transfer.it for it.
@trebleta Okay, i will check your backup later and compaare it with your backup bios. For now do not FPT flash that F13c as it might delete the motherboard specific data (since fpt is pure flashing, override the bios chip with the bios file as-is), so i might make a few transplant from your backup to this F13c from your backup you’ve sent. Stay tuned
Hmm I’ve noticed I have another f13c version, the lastest should have GK CF not sure if its the one I shared.
I went to gigabyte and got the GK-CF version they gave me again, yet can’t share from my mobile, soon as I get to the pc shortly will update from them plus the picture that gave me.
this is the last version from e-support of the f13c i got
When I tried what Gigabyte ask, I booted in to the backup bios F10 then switched the switch to main bios when in the bios, flashed the bios with f10 that did not work so i tried f13a and yet the f13c still did not get overwritten, the backup bios got overwritten! so now my backup bios is f13a, even though I switched the switch when in bios from backup to main bios. Before capsule bios I could enter backup bios and swap switchs from single to duel bios and alt f10 and would flash the main. that failed also. the pc locked up.
So basically, you have Bios F13f, and now you’re having problem with F13c wont update to F13f, and you now want to downgrade to F10, then update to F13f?
If you want to update to F13f but kept having OEM ID mismatch, maybe sent that bios instead of F13c? Sorry, i was abit confused on what you aim previously.
