My mobo gigabyte B85M-D3H can’t boot after replaced cmos battery, its turns on and then off continuously, I have clear cmos with short pin but still not work, before battery replaced it’s work perfectly with nvme and windows 10. What should I do ?? How to reset bios modified ?
Set the bios back to pure UEFI mode and not the default setting of CSM to never and W8 features enable, on boot manager set priority disks if having multiple OS/disks, by default should be selected Windows boot manager as primary when only a NVMe boot disk OS present.
Iam sorry mate, but the mobo can’t running, when I press power button the mobo turn on 2 - 4 seconds then off, turn on again 2-4 seconds then off ..continously. How I set bios ?? Should I flash bios chip with bios flasher ??
You can try to turn the power (psu) off, press and hold power button for 10 seconds, release and then power it on, press and hold power button and reset button for 11 seconds (make sure reset button is connected to the mobo header), it will power on and then power off itself, and if it stays off after turning on for a while during you’re pressing and hold both power button, release both (after 11 seconds), and power it on manually, backup bios will soon kick in and restore main bios
I have tried it, but still looping, maybe the one of resistors or chips is damaged.
Yeah…usually users omit their initial issues, so start by telling us the reason for CMOS exchange, did the old battery was really low on voltage?
Before exchange battery I saw on screen error bios with three options : 1. Load optimized defaults then boot 2. Load optimized defualts then reboot 3. Enter Bios. If I choose number 1 the mobo can booting normally.
So I assum the battery cmos should change with new battery. But the mobo looping and can’t start after I changed the battery.
“Accidental” cmos reset can occur in various “situations”…the question is, is it a drained cmos battery below 1 or 1,5v or another fault that cause it.
The initial loop after loading optimized with OLD battery is correct as it occurs when bios settings return to CSM/Legacy, these are not modern boards that by default prefer Auto or UEFI and in this case an old board with a mod needs manual settings as previous mentioned.
So, the loop remains with OLD or NEW CMOS battery, if after proper bios settings for NVMe mod/boot, NVRAM doesnt get stored and voltage is enough in CMOS, there’s other issue around somewhere.
Nothing more to add, good luck.
Thank you very much for your explanation, and amazingly, after leaving it without power for two days, I tried turning this mobo back on and it turned on. I am very happy now
. However, a small problem at the beginning… the three options that appeared during booting still appeared.
already told you…“if after proper bios settings for NVMe mod/boot, NVRAM doesn’t get stored and voltage is enough in CMOS, there’s other issue around somewhere.”
So enough voltage/healthy cmos battery the options won’t appear again and settings get stored…if not… if setting is stored and proper UEFI boot is set you would already report this…but you didnt, so it’s alive but…
This problem has always existed on Gigabyte motherboards since the first series of DUAL BIOS was released. This problem has never been related to the processor or RAM on the motherboard.
Even if you reset the CMOS or rewrite the BIOS, the same problem will occur.
In fact, it has absolutely nothing to do with the BIOS software.
Gigabyte motherboards rarely create BIOS software problems.
So what is the problem?
Almost 99% of Gigabyte motherboards use solid capacitors, and this is caused by a small voltage buildup inside the capacitor that cannot be released.
My favorite high-quality Japanese solid capacitors are used in Gigabyte motherboards, and this is the main reason why they give higher overclocking values. But here’s the disadvantage: because there are two BIOS chips on the motherboard, a temporary instability occurs. In short, the small voltages accumulated in the solid capacitors react in reverse, causing the motherboard to hesitate about which BIOS chip to read, and it constantly tries to shut down and restart in the same cycle to try to recover from this error. But the solid capacitors don’t allow this. By disconnecting the power supply from the motherboard and without any power, this problem can be solved with a simple procedure: short-circuiting the small capacitors around the processor using a screwdriver tip. @MeatWar has naturally described this and suggested the correct solution. Keep this information in mind for Gigabyte motherboards.
I almost forgot to add this.
Why doesn’t this problem exist on other brands of motherboards?
Because other brands of motherboards don’t have DUAL BIOS, and those that do use a switch for switching. Gigabyte has automated this.
When asked which motherboard uses the worst solid capacitors, my answer would be MSI without hesitation.
I’ve never seen a motherboard use such shoddy solid capacitors as MSI.
At one point, MSI used ordinary capacitors around the CPU in 775 sockets instead of the required high-quality solid capacitors, and almost all the motherboards became scrap. If you’re wondering how I know this,
I’ve been repairing motherboards for 30 years and have encountered these cases many times.
Many thanks for the information you provided. It was very helpful. I almost replaced my motherboard with an MSI, but after hearing your explanation, I decided against it. Thankfully, my Gigabyte motherboard is still working fine. Thank you.
Hello @Hawwin88 !
I won’t say for older Gigabyte motherboards,
but for boards of the 100-300 series, the DUAL-BIOS System works as follows:
- after an unsuccessful start or damage to the main firmware M_BIOS, the system after 3-4 unsuccessful starts should automatically switch to boot from the backup BIOS chip B_BIOS on which a full BIOS is located, it can be of a different version, either newer or older;
- in case of a boot loop and the inability to automatically switch to B_BIOS, you can simulate a malfunction artificially - for this you need to press and hold POWER. The board will start for 1 second and turn on completely. Release it again and press POWER. so 3-4 times in a row. Then, when you press POWER again (you no longer need to hold the button), the system will automatically boot from the backup B_BIOS.
Such an algorithm will work even when M_BIOS is in good condition. - I personally checked this on Z370PD3, I have different BIOS versions on 2 BIOS chips (F15b and F16d), moreover one M_BIOS chip is Winbond 25Q128FV, the second B_BIOS is MX25L12835F !!!
Thanks/
