Hello everyone,
I am working on fixing a persistent Code 43 error on my NVIDIA GeForce MX130 (Maxwell). This issue occurs in both Windows and Linux (dmesg shows BAR allocation errors).
After analyzing my BIOS dump (InsydeH2O) via IFR extractor, I suspect that the default Lenovo NVRAM configuration doesn’t allocate enough resources for the GPU to initialize properly. Specifically, my Aperture Size is locked at 256MB, while the GPU likely requires a larger window (2GB) to function without resource conflicts under modern OS environments.
I am planning to use RU.efi to modify the following variables, but I need a sanity check on the offsets and the platform’s behavior.
My Platform & Diagnostic Info:
Model: Lenovo IdeaPad 330-15IKB (Type 81DC)
Platform ID: EG521
BIOS Version: 8RCN58WW
Intel ME Status: Active and healthy (Sunrise Point-LP CSME HECI #1 visible via lspci).
Identified NVRAM Targets (extracted from IFR):
BIOS Lock: VarStore 0x05, Offset 0x17 (Currently 01). I plan to set this to 00 first to allow writing.
Aperture Size: VarStore 0x02, Offset 0x42 (Currently 256MB). I want to set this to 03 (2048MB).
Above 4GB MMIO BIOS assignment: VarStore 0x02, Offset 0xE4 (Currently 00).
Memory Remap: VarStore 0x02, Offset 0x19D (Currently 00).
A critical note from my IFR: The IFR text explicitly says: “Note: Above 4GB MMIO BIOS assignment is automatically enabled when selecting 2048MB aperture. To use this feature, please disable CSM Support.”
My Questions:
Given the “Automatic Enablement” note, is it safer to only change the Aperture Size (0x42), or should I manually force Above 4G (0xE4) and Memory Remap (0x19D) to be sure?
Are there any known “Watchdog” or “Post Error” triggers on the 81DC platform that might cause a boot loop if I change these specific values?
I have identified “BIOS.fd” as the likely Crisis Recovery filename via strings analysis. Can anyone confirm if the Fn+R routine on this specific model is reliable for an NVRAM reset?
Updates i forgot to add here
I wanted to send my bios and some things that would help you but im new and im not allowed to send any zip files so sorry.
In UEFI Shell, on low frequencies like 145mhz (as gemini said) it worked too, i tried to save like vram files im not sure how to say that, and it saved everything, there wasn’t just 0000-0000-0000 or FFFF-FFFF-FFFF, so, atleast we know that my gpu works well here
I dont have my recovery flash drive ready (what i want to do is make a fat32 partition on my drive, put the bios file in lets say D:\BIOS.fd and use a special id from diskpart to make it bootable if it would help for Chrisis Recovery and if its not gonna work im gonna buy one, just tell me if my idea would work). I’m trying to be as careful as possible before committing changes to NVRAM. Any insights from those familiar with Lenovo’s InsydeH2O implementation would be greatly appreciated!
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title shortened/customized
