Hi all,
I’m trying to enable Above 4G Decoding on a Lenovo ThinkCentre M90q (Gen 1) to get an RTX 5060 Ti 16GB recognized via OCuLink eGPU. The GPU is completely absent from the PCIe bus — lspci shows nothing from the eGPU dock.
System details:
- Machine: Lenovo ThinkCentre M90q (Gen 1)
- BIOS version: M2WKT63A
- CPU: Intel Core i5-10500
- RAM: 32GB DDR4
- OS: Proxmox VE 9.2 (Debian 12 base)
- eGPU dock: AOOSTAR AG02
- GPU: NVIDIA RTX 5060 Ti 16GB
- Connection: RIITOP PCIe x4 to OCuLink SFF-8612 adapter card in the M90q PCIe slot → RIITOP SFF-8611 male-to-male OCuLink cable → AOOSTAR AG02 dock
What I’ve confirmed:
- VT-x (Intel Virtualization Technology): Enabled in BIOS
- VT-d: Enabled in BIOS
- Active Video: set to IGD
- Secure Boot: Disabled
- IOMMU is active and working (dmesg confirms Intel VT-d)
- Physical connections are fully seated at both ends
- AG02 dock is powered on before the M90q
- The BIOS does not expose Above 4G Decoding or Above 4GB MMIO BIOS assignment anywhere in the visible menu
lspci output shows the PCIe x16 controller at 00:01.0 but nothing downstream — the GPU is not being enumerated at all.
I found a thread here for the M720q (a close platform relative) identifying the setup_var offset for “Above 4GB MMIO BIOS assignment” as 0xA49 with the command:
setup_var.efi 0xA49 0x01 -s 0x08 -n “Setup” -i 0x01
My question: Is this offset likely to be valid for the M90q Gen 1 with BIOS M2WKT63A, or do I need to extract the offset from my specific BIOS file? If the latter, can someone point me to the correct process for this platform?
I’m comfortable working in a Linux terminal but have not done BIOS variable extraction before. Happy to share any output needed.
Thanks in advance.
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
