Good morning, I hope to learn more from you all. I’ve been reading and learning a lot for about two months, but I’m finding it difficult to make progress.
If for any reason this message is inappropriate or bothers anyone, I will delete it and continue testing on my own. In advance, if this is the case, I apologize.
I have several jailbroken ThinkPads. Among them, I’m struggling with a T480 20L6, i5 8350u, region ME 11.8.60.3561. The laptop booted correctly, but it had a supervisor password. I made a backup with a Raspberry Pico using flashrom and tried to remove the SPW with Lenovo autopatcher02, but it didn’t work. When I connect the charger, the T480 powers on for 1 or 2 seconds the charging LED, power button LED, keyboard backlight, and fan. After this, and while the charger is still connected, the fan makes random, intermittent bursts every few seconds. So I flashed the original dump again, but the same thing I described is happening.
I don’t know if it’s related to the fact that I turned off the T480 using the “Disabled Battery” option in the BIOS before creating the original dumps.
I’ve attached the original dump in case someone can look at it and help me fix it.
Thank you very much.
Best regards
T480_Original_1.zip (8.7 MB)
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
