I’m encountering a serious issue with my ASUS TUF B560-PLUS WiFi motherboard after updating the BIOS to version 2803, and I’m hoping someone here might have insights or a solution.
Problem Description
Immediately after flashing BIOS 2803, the system no longer boots normally. Instead, it displays a message indicating that it is “Updating LED firmware”. The process counts down for about three seconds, then the system automatically restarts. After rebooting, it returns to the exact same LED firmware update screen, waits three seconds, and reboots again. This cycle repeats indefinitely with no way to enter the BIOS or boot the OS.
Current Behavior
System powers on
Shows “Updating LED firmware”
Waits ~3 seconds
Automatically reboots
Re-enters the same screen
Loop continues endlessly
There are no error codes, no beeps, and no opportunity to interrupt the process.
Additional Information
The BIOS update was performed normally using the built‑in EZ Flash utility.
The system was stable before the update.
I have a CH341 programmer available if a BIOS chip reflash becomes necessary.
Request for Help
Has anyone experienced this LED firmware update loop on ASUS motherboards, especially after BIOS 2803? Is there a known fix, recovery method, or workaround to break out of this cycle? If a manual BIOS reflash is required, any guidance or confirmed working procedure would be greatly appreciated.
Thank you in advance for any suggestions or insights.
Edit by Fernando: Thread moved into the „Bios Problems“ Category and title shortened
Hello Moderator, I’d like to ask: based on the rear I/O layout and the information I’ve found, the B560 PLUS does not support USB Flashback. In that case, where exactly should the USB drive be inserted on the back panel? Also, is a 16GB USB drive formatted as FAT32 suitable for the upgrade? If updating the BIOS firmware via USB is not possible, are there any alternative methods?
The boot screen on my motherboard currently shows the following message, and after waiting for 3 seconds it automatically restarts. This loop repeats endlessly. (Since each reply can only upload one image, I had to split it into two posts.)
No, this board has no BFB feature and no dedicated port but it does update by USB with Asus bios embedded utility (EZ), not on Windows environment.
Since now the board is on loop, probably you won’t get access to bios for this, so last thing to try, as previous mentioned is file in USB and on root of main disk.
If still on loop, you’ll have to program the IC(s) one by one with CAP file without header and/or probably the CS FW on second IC if present.
Initial research shows only 1 IC for this mb model, you need to confirm it yourself.
Hello Moderator, Yes, the B560 PLUS WIFI has only one BIOS chip, and the chip model is CigoDevite 25B127DSIG. I have a CH341 programmer here, so I’m able to flash the BIOS firmware directly. The issue now is that I’ve already tried flashing both the 1601 and 2803 BIOS versions using the CH341, but the system still goes into an infinite reboot loop. Do I need to modify something in the BIOS firmware, such as disabling the LED module, in order to make the system boot normally?
I dont think that’s possible and never saw such action.
You need to check the board schematics/boardview if available, i do not have it to this model but i dont think you have the knowledge for that as you are maybe just a regular user and never have done this before, why dont seek a repair lab.
Assuming that the APP used is correctly doing the ID/writing of the IC and verified back, why dont you try older bios files lower than 1601 or initial one.
That’s all from me, you may wait for other users PoV, good luck.
