[Problem] MS Surface Pro 6 doesn't boot
Hi all,
I have a Surface Pro 6 1796 i7 16GB 512GB.
The original problem is that the device shows the Windows logo, then stops with BlInitializeLibrary failed 0xc00000bb.
There is no boot loop, just a hang after that error.
I received two modified BIOS files based on my dump, but neither works.
On Badcaps, I got very little feedback, so I’m asking here as well.
I also re-dumped both modified versions after testing and uploaded those files too.
Maybe someone can compare them and spot what is wrong in the BIOS region, UEFI structure, ME/descriptor area, or elsewhere.
Here the extracted UEFI from Surface Pro 6 Update Package
Any help is appreciated
Simu
Edit by Fernando Thread title customized
@Simu7
Welcome to the Win-Raid Forum!
Have you ever gotten a Windows OS properly installed and running? If yes, which one?
According to GitHub The “blinitializelibrary failed 0xc00000bb” error indicates that the Windows Boot Manager cannot start the operating system. This usually happens due to severe UEFI memory fragmentation, misconfigured BIOS/UEFI settings, or corrupted Boot Configuration Data (BCD).
Hi Fernando, thanks for the quick response.
As far as I know, the problem started after a Windows 11 update. Before that, the device was working normally.
I forgot to mention that neither USB boot nor entering BIOS/UEFI works.
Thank you again for the fast reply.
