Need some urgent help please to rescue my laptop MSI GL65 9SEK
I have updated the bios via an external USB, flash was successful, downloaded the file from MSI official website for my laptop, but after successful flash, laptop went off, does not boot again at all.
1- It was booting for 5 s, keyboard lights on but goes off immediately, it does not give you any chance to boot from another external disk or even get to bios menu
2-tried to flash again same bios on chip using CH341B, flash is successful, but laptop does not boot and no sign no fan no light.
Need some help if anyone got a back up copy of bios full data: MS‑16U5 / GL65 9SEK full 16MB dump with FD+ME+BIOS for MS‑16U5 E16U5IMS.102 or even 101.
Many thanks in advance
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
Many thanks @MeatWar for sharing if you have a good complete bios file with bios/EC… , i did not remove the usb or moved the laptop at all,flash went successfully till the end, something went wrong at restart after bios update.
Will give a try to the file you shared and hopefully this can help
Flashed the file you gave @MeatWar , went successful, removed battery and cmos battery, power off while doing it.
After flash, did a reset power cycle 2min on power button, no batteries…nothing up after that, done a power cycle reset again : removed 1 ram/SSD drives/WiFi card all waiting time 30 mins, after that, batteries in + power nothing again
Ai recommendation is to desolder the chip and program it then solder it again, seems there is a lock see:
“MSI GL65 MS‑16U5, Boot Guard 5. In‑circuit SPI flashing triggered a bus lock. Please desolder the BIOS chip, program it externally with this full 16 MiB dump, and re‑fit it.”
