[Problem] No Display on Lenovo Tab M10 Gen3
Hi, I have a question. I replaced the screen with a substitute one, and after disconnecting the battery and LCD cable from the motherboard and reconnecting them, the screen displays no image at all. I hear the tablet vibrate for about 5 seconds and then nothing displays. Has anyone else experienced a similar problem? Is there a solution for this specific issue or the entire procedure for a Lenovo tablets?
P.S. When I first replaced the screen, the old WAN cable was damaged but still displayed something, but now even the old one is black.
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
Same issue on several Smartphones LCD replacement using very VERY cheap aftermarket LCD’s/Touch… unless any flat/cable has damage and not yet discovered…
…errrrrr.
I can always try to find other LCD and resend back this one :smiley:
