[Problem] No POST on Intel NUC8i7 (HVK)
Hey good people this is my first post on the forum in hopes of getting some help from the experienced experts here. I have an Intel NUC8i7HVK Hades Canyon that will not POST or display anything and as soon as I connect the power adapter the device turns on. I have tested the motherboard and found no faults so my assumptions were that there is some kind of Bios problem, I went ahead and used my programmer to dump the original file and while researching this forum I found a dump file posted by a member of the forum and I went ahead and flashed the bios chip. The device now powers on normally (with power button) but the post screen only shows up after about a minute. I managed to install an OS and all the drivers (technically the device is functional) but im having problems with Intel ME and ofcourse im missing all my Bios region data, serial keys and so on which is also not allowing me to install intel ME.
Is there anyone who could rebuild me a bios file for my device and exctract all necessary information from my dump file to get this little machine running properly.
If any other information is needed that I skipped please let me know. I have attached the original bios readout file.
PS I have tried bios jumper recovery with no luck.
Thank you
Regards
Alex
NUC8 HVK ORI dump bios SPI W25Q128JV.zip (5.4 MB)
NUC8 HNK Winraid dump bios SPI W25Q128JV.zip (5.6 MB)
Edit by Fernando: Thread moved into the ā€œBIOS Problemsā€ Category and title customized
You lost your NVRAM completely, see pic. It might be possible to restore some of the machine data, I’ll have a look into it later or tomorrow.
Thank you so much for having a look at it. I have also been trying to investigate the file with UEFI Tool and FIT but as I am not really experienced with these kind of repairs im not really sure what I am doing :joy:
I also noticed that something is missing just have no clue what. I bought this NUC off someone on FB Marketplace as a secondary unit as I own one for 5 years now. Im not really sure what happened to the NUC, looks like the previous owner failed a BIOS update, as the machine is really clean inside I assume they didnt really get the chance to use it much. Thought I could get this one running so i could claim my one back from my wife :rofl: she really loves these little machines.
Try, no warranty!
NUC8 HVK OR SPI W25Q128JV_ME_NVR.zip (5.3 MB)
I come back with good news! The file so far is working great, the POST has no delay and all Intel ME drivers installed perfectly. POST says: ā€œSystem in manufacturing modeā€ on power up, but I read online it should go away after 20 reboots. All i can say thank you very much!
Regards
Alex
Thanks for the feedback. Good to hear it worked!
The firmware posted had the ME region reinitialized (according to this guide) and there were some parts of one NVRAM still readable. NVRAM gets rebuild automatically, but reconstructing NVRAM with the DMI information might give som unexpected results.
There’s actually a variable MfgMode which I put in again, but it might be reset since the secure boot databases and several values have to be rebuilt again.
I’d recommend
  • to make a backup after several restarts / when the message about Manufacturing Mode has disappeared. You might try to use Intels FlashProgramming Tool fpt from
    CSME System Tools v11
    For CSME v11
    (File folder on MEGA)
    from this thread.
    Syntax would be
    fptw64 -d spi.bin (for the whole SPI) or
    fptw64 -bios -d biosreg.bin (for the bios region- and that’s the only part with relevant changes now)
  • to update to the latest firmware version (it’s now on Asus’ websites) as last step
If you can get a backup of the bios region I’d be interested how the NVRAM looks when the manufacturing message disappears!
Hello apologies for the late reply I havent had time to carry on work on the NUC as I left it at my workplace over the weekend and I am still waiting for another NVME to arrive. After I flashed the bios chip with your file I already had Windows installed on the NVME so the system booted up straight into the OS. Today I noticed the manufacturing message is gone but I also noticed secure boot has been disabled in bios, I dont plan on enabling it again as I’m not sure will that require an OS reinstall. What i can tell you is I did straight away update the bios to version 0067 from version 0064 that was on the file supplied. I will be making a dump of the file and posting it here for your further research. Is it fine that i have already updated it? Otherwise everything seems good so far havent had a chance to test performance as I still want to change the paste on the CPU/GPU. So with the tool you posted above I can make a full bios dump without removing the bios chip?
Regards
Good to hear that the manufacturing message already disappeared. Then this system should be fully recovered now.
Secure boot normally isn’t posstible without db, dbx, pk and KEK reinstalled in NVRAM, but you should be able to enable secure boot now. There shouldn’t be any need of reinstaling Windows.
Didn’t find any OEM Windows activation in the firmware, by the way.
If you have the time to make a new dump of the bios region by software I’d be happy.
Firmware 0067 doesn’t seem to be the latest:
(image clickeable)
Seems to from late 2022, new date possibly since Asus took over
The tools mentioned (fptw64.exe) often give the possibility to dump a complete image, sometimes one region doesn’t have read access. If they work this is the most safe and comfortable way.
SInce FD and GbE normally don’t change and you already have a clean ME- region bios-region is the most interesting part. Be careful with the syntax, though!
Thanks for the reply, I am aware of bios 0070 but my other NUC unit has been running 0067 for a long time and i found it very stable (including using older amd drivers for the radeon graphics) if you would prefer an update to 0070 before the dump I can do that too as this unit is open for experimentation. Also I have made a dump of the 2nd SPI chip, also the GPU spi chip, I could also post those here if you have any interest in it.
The update to 0070 isn’t relavant. I’d like to have a look into NVRAM at the ā€˜earliest’ possibility after it’s been rebuilt, that’s all.
The other 2 chips would be of course relevant, just have a look and to compare to what might be in the update files!
Sorry for late reply here are the dumps of bios 0067 after manufacturing message disappeared, also I will upload SYS2 SPI dump and GPU SPI dump. Thank you for your help.
SYS SPI HADES CANYON 0067 (Manufacturing mode off) W25Q128JV.zip (5.5 MB)
SYS2 SPI HADES CANYON W25Q80DVSIG.zip (144.3 KB)
GPU SPI HADES CANYON MX25L4006E.zip (99.7 KB)
Thanks! The smaller ones are grapics card and Thunderbolt, and both aren’t in the normal firmware update.
Regarding the dump of the bios region: The NVRAM has become too large already, but that’s not a problem. To know that this type just needs these 4 values and StdDefaults is good enough!
Enjoy your recovered NUC :slight_smile:
Hi Alex,
sorry to bring this topic back. Is it possible to let me know the spi model? is it W25Q128JV, and with JVxx? or just JV? is the voltage 3.3V?
Thanks
Diego
the XX doesn’t matter to regular users, this is just the package type and temps specs from the vendor, the base reference model is JV
Thank you so much.
Hi just to reply the chip ends with JV.
Hello Sir. Can you please help me. i have NUC 8i7HVK with same problem. suddenly it stop to show picture at all. but powering on normally power light solid blue and green light solid green. but no picture from any of the outputs. i tried to flash the w25q128jv chip with your dump (SYS SPI HADES CANYON 0067 (Manufacturing mode off) W25Q128JV.zip) and now when i press the button the all lights flashing once shortly and unit not start. i tried then reflash it with factory 0059.bio file and the situation same. nuc not start
can you please tell me what i do wrong? i use Ch341a programmer with asprogrammer tool. chosen the chip JV correctly. it flashes so long like 2 hours to flash. maybe the JV chip broken? how i can diagnose this? i ordered another new JV chip and its still on the way. but i do something wrong i guess. Since its no support from Intel anymore they ignoring the messages, and from Asus no support too, i not know where i can find support
i have a question. when i try to refresh the spi today and the model that neoprogrammer detected is MX25L128*** instead of W25Q128JV. it’s weird
Why is it weird? Who told you that the stated IC model has to be the same on every motherboard?
General rule for pros and noobs…visual inspection and technical details of every IC, before any programmer physical connection…sir.
Hello you wonderful tech wizards, much like the original poster this is also my first post on this forum I’ve read all the comments and would be very grateful if one of you kind individuals might be able to point me in the right direction. I too own an Intel Hades Canyon NUC however it is the NUC8i7HNK (slightly lower powered variant) which also has similar symptoms as to what @Shadowcoa posted (does not post, nor has any display output)
I initially tried the power button and security jumper recovery methods however had no luck. I then stumbled across this forum and went ahead and dumped my bios (3 times just to be safe) It uses a different variant of the SP1 chip MX25L12873F I believe the bios version is 0067 which can be found on asus website. I have attached two copies of the .bin file which was dumped using neoprogrammer.
As far as I can tell from the activity lights the NUC is functioning (powers on ok, HDD activity light suggests activity, keyboard and mouse light up and connect) but there’s no video output on HDMI or DisplayPort’s (attempted different monitor / cable combos) so I’m hoping someone might be able to review the attached file and maybe look at the original and see if its potentially a bios issue.
I will be forever grateful if one of you could point me in the right direction.
NUC8 i7HNK NeoProgrammer dump bios SP1 MX25L12873F
NUC8i7HNK bio from Asus
