Hi everyone! I want to turn my Dell Optiplex Micro Plus 7010 into a Dell Precision 3260 Compact! So, I’m calling on Dell Precision 3260 Compact owners—I need your help!
Soldering the SATA 0 connector wasn’t hard!
I soldered in an x8 connector—easy!
And that’s when the trouble started! The device wasn’t being detected, so I started analyzing the motherboard. Here is what I’ve found and know so far:
PRSNT1# – hard-wired to ground.
PRSNT2# (B17/B31/B48) – 3.3V; when the device is inserted, these pins are pulled to ground!
CLKREQ# – always 0; it’s simply missing!
WAKE# – 3.3V.
PERST# – I got the correct signal by soldering in the chip and the supporting circuitry, including a capacitor for a 100ms delay.
PWRBRK# – ?
TX lines – filter capacitors are needed!
I need any help or tips! I don’t have the original riser; I was working from photos! But logically speaking, there’s nothing special about it other than stepping down the voltage from 19.6V to 12V!
The photo shows the back of the board, below the PCI connector!
Photo: Before
Photo: After
Photo of the original riser
Here’s what HWinfo shows
and here’s what I sometimes manage to get
But the device itself doesn’t show up!
Edit by Fernando: Thread moved into the „BIOS Problems“ Category and title customized
