[Problem] Quad Channel LAN Connection of Machinist X99-U9
I was using a Machinist X99-U9 motherboard with a Xeon E5-2696 v4 and 64 GB of RAM (2 x 32 GB DDR4 2133 ECC) in dual channel. Recently, I acquired another 64 GB with the same specifications and brand to enable quad channel, and the BIOS recognized it without problems, as did Windows 11. However, the network connection started dropping, and after several tests, swapping the positions of the memory modules and reinstalling the drivers, I discovered that the problem is due to the quad channel configuration, which is probably overloading the internal PCIe bus and resetting the network controller. When I remove the additional 64 GB, the network stabilizes… Has anyone experienced something similar and could help me understand the problem?
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
This sounds very strange on many levels, and your explanation makes no sense whatsoever. Just why would quad channel configuration overload the internal PCIe bus and reset the network controller? Never ever heard of, or experienced that.
Faulty RAM and/or bad connections are in my own experiences the most likely root cause. So of I were you, I would:
  • Start by cleaning the hardware
  • Stress test each individual RAM stick, and see if there are any problems. My live USB stick is very useful for this purpose
  • Stress test each individual RAM slot on the motherboard
  • Stress with more and more sticks, until you encounter problems
