Hello, I’ve got this issue on my pc lately, where i had tpm 2.0 working all fine on my laptop, until somehow i don’t remember exactly why and when, i checked and found it off, thought if i could enable it from bios, but all led to nothing since i got no option to enable it so, tried to flash the latest bios, still same issue, so i thought maybe someone can help me out mod this bios please ![]()
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
Sir…there is no Intel PTT/TPM2.0 modding for an already supported system.
Both CPU and chipset supports the technology as well being a Windows 11 default machine, for sure Asus didn’t remove such feature on a modern system..
Overwrite current last bios again, but this time by Asus bios interface utility, loading the CAP file from a USB, not Windows environment or Asus apps.
Do not remove the USB until system boots into Windows OS again.
Some systems require an ADMIN password to be set in order to access advanced security options.
Ask Asus for further guidance or load bios default and do a CLEAN OS installation from fresh start. System should be set as “PURE” UEFI class, no CSM.
u don’t believe me if i told u, ive done everythin i could, including installing the cap file from usb, clean os install, adding admin pass, yet nothing changed.. i really wonder how is that even not fixing the issue
How’s the state of the CSME FW of the system?
Have you tried to do a COLD reset, unplugged internal battery?
i tried unplugging my battery, waited for 5 mins and turned it on, didn’t work
and for CSME FW, idk tbh
Can you see CSME FW version in bios?
Do you any yellow exclamation mark device in Windows device management?
Show me the menu where previously you had the PTT security feature available.
EDIT:
Can you make a backup of the current bios…are you familiar with Intel FPT or AMIAFU?
If so you can still check CSME FW with platomav/MEAnalyzer: Intel Engine & Graphics Firmware Analysis Tool
Or an easy way…if HwInfo doesn’t show any ME FW version, it’s off or corrupted and this has major impact in security and features.
No CSME FW version available on bios to check…no error in Device manager, you got a “deep firmware” corruption or maybe an hw failure (a tech lab pro can try do re-program it) or diagnose further into hw, or contact Asus support before going to a tech lab, good luck.
This is the issue, there is no option for that on this bios, as I searched, It’s build like enabled by default, and u cant have the choice to do anything about it, but bro if u solve this one u r gonna my all time goat
Present but PTT in FW as “Not capable”, contact Asus first and provide this info and your general view.
*NOTE; We are using here 3rd party tools…
Thank you for your time sir
