After downgrading BIOS it is recommended to clear CMOS and load optimized defaults to remove any remnants of the previous configuration as it can sometimes cause weird issues.
Got ya
Fast Boot can stop you from booting from USB devices so I would check if it is disabled.
If fast boot is already disabled is CSM enabled or disabled?
Had that disabled already.
Handbrake will work your CPU very hard, especially if using AVX2. Haswell/Devil’s Canyon has no AVX offset so you will need to monitor your CPU temperature to see if your CPU heatsink is adequate and if there is any CPU throttling. Throttlestop is very useful for monitoring for any type of throttling in real time.
I actually doubt that cause the second I run my program it immediately shuts my computer off, I doubt it can raise the temperature in one second. But yeah both uses AVX so yeah.
Can you please list your full PC specs (including the hard drives, CPU cooler and model/age of the power supply)?
For Drives, One is a kingston, another is a samsung, both are ssd and non OS drive is harddisk drive I think brand is WD.
CPU is i7-4790k
as stated bios current version does not even support my cpu.
CPU cooler is liquid cooler. I ran the same program on my laptop and a crappy desktop computer with no liquid coolers so that doesn’t crash.
PSU model is RS-A00-AFBA-G1
Have you checked the voltage rails of your power supply in the BIOS?
No but I haven’t modified anything to do with voltage.
Do you have XMP enabled?
Nope nothing is overclocked.
Your RAM could also be a source of instability, I would test with XMP disabled and just use the SPD profile to see if the system stabilizes under load.
Already done a mem86 test on it (if that is suffice) and it passed.
When you installed Windows did you use AHCI mode or was RST enabled?
AHCI.
