[Problem] Updating GA-H610M S2H DDR4 rev 1.3 MB BIOS
Guys i have gotten a new cpu i do everything right but i keep getting the error called “not able to update bios files successfuly” error and i just wanna update my bios to use my new cpu lmao i would appreciate the help.
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title cutomized
What CPU model? What current bios version in the system?
Power off, CLR CMOS, remove CMOS battery, drain.
Power on, enter bios, Use Q-Flash (F8) embedded in Bios setup, sourcing from a USB disk.
I3 13100f FL version and they do not work
Use a usb stick formated in fat32 and below 32 gb.
bro i have already done that
FL version is too old and earlier cpu patch/mcode were implemented in the following versions, you got to do an incremental version update and not jumping into the latest.
Else explain the issue to GigaByte support.
