Hi Fernando and everyone!
I have some problems with my MB.
Recently i buy a more one samsung 512gb nvme 950 pro, for make a raid 0 for other.
In AHCI the two ssd works fine!
But i set for RAID 0 on first reboot the oc dont boot. After force a shutdown, i can set the raid 0 and select the ssd…
But when the problem is when i select the driver for RST i get the same error 0x8007054
The problem is wth my version of rom? That is 14.8.02377
Someone can help?
Thxs!
@eduaf1 :
Welcome at Win-RAID Forum!
It is not easy to help you, because your photos do not show all required details. Why haven’t you taken screenshots and attached them? It should be even possible from within the UEFI BIOS (F12?).
Nevertheless I found something, which you have done the wrong way: You didn’t unplug all other disk drives except the M.2 modules before beginning to create the RAID0 array.
The LEGACY mode Intel RAID ROM version doesn’t really matter, because the Intel RST RAID Utility uses the EFI RAID module named “RaidDriver” (previous name: “SataDriver”).
By the way: >Here< is a video about how to create a RAID0 array with 2 Samsung 950 Pro M.2 SSDs.
Regards
Dieter (alias Fernando)
Hi Fernando! Thanks for your reply!
Can be more easy in Spanish… but here we go…
The photo i have shot of my cellphone thats the question? You need more quality of images?
I see this video a lot! And i sure all in this video i maked…
Sorry for my bad english…
i dont unplug any hdd ou dvd drive, when a i make the raid… i need this?
Thks!!!
Best regards
I am sure, that you didn’t unplug all disk drives, although it is mentioned in the video to do it.
It may be not absolutely needed, but it is recommended to do it to avoid any problem.
Thanks so much!!!
The hdd having some trouble for detect raid on OS installation!
I need make a new installation, but the raid 0 works fine!!!
Best regards!!!
You are the BEST!!!
