Problem with Z490 AORUS ELITE AC after BIOS update
Hello, the problem concerns a Gigabyte Aurus Elite AC Z490 motherboard, version 1.0.
Four years ago, when I flashed it from version F4 to a higher version (I think F21) via QLFASH, I was unsuccessful. The motherboard showed no signs of life. I desoldered the MX25L25673G BIOS chip and tried to read it (CH341A), but there were problems with identification and reading. So I don’t have the original BIOS chip (which was there). (I now know it was a clip issue, but I misplaced the chip somewhere).
Now I wanted to revive this motherboard and ordered a chip from eBay with the F24 chip. When I read the chip, the contents matched the F24 file from the Gigabyte website 100%. Unfortunately, after soldering, the motherboard doesn’t respond to the power switch.
So I decided to program the F4 flash (which is probably what I had four years ago before the update) from the manufacturer’s website. MeanAlzyer shows me how it’s configured. The FIT analysis shows correct firmware, firmware update, and BIOS are present. And bingo, the board responded to the button and started up. It reset twice and stopped at the DRAM debug LED without displaying anything. After 10 minutes, I turned off the power supply. After that, the board doesn’t respond at all to the power button, either with the F4 flash or any of the Gigabyte ones.
The QFlash function starts for 75 seconds, the QFlash LED flashes, restarts with the CPU LED, and then turns itself off. I soldered in a clean chip, hoping it would program correctly with the ITE5702 chip. After reading the flash, it only writes to offset 00000090. And that’s it.
I purchased a BoardView for this board and measured the voltages around the ITE8688E, PCH, and ITE5702, which corresponds to the QFlash. The voltages are present and correct according to the BoardView markings. There are no short circuits. The SPI memory signal lines also have continuity to the ITE5702 and the PCH bridge. So the board seems to be electrically fully functional.
I decided to check the memory communications using a logic analyzer – CS, MISO, WP, HOLD, and VCC are present during standby and when attempting to boot the power switch. However, MOSI and CLK are not present.
Is this a blockage/fault in the PCH, the ITE5702, or a firmware issue? Will this board still work? If so, what steps should I take?
Bios link: https://www.gigabyte.com/pl/Motherboard/Z490-AORUS-ELITE-AC-rev-10/support#Support-Bios
I hope someone has experienced this before and can help. I’m also counting on the help of user @lfb6, who, having searched the forum and seen other threads about bricked motherboards, has a wealth of knowledge.
Thank you in advance for any help and information on how to fix this motherboard.
Try to program the F21 and then Q-Flash_PLUS button with F22a, prior to CAPSULATED versions.
After applying power, the CLK is detected by the analyzer.
The QFlash Plus function started working correctly, and the flash write takes about 5.5 minutes. So I checked by flashing versions F4, F21, F22A, and F23, F24, F25A one by one. After each flash, I cleared the CMOS short and removed the 3V battery for 10 minutes.
Unfortunately, the power button still doesn’t respond.
