[Problem] XCY Computer w/o TPM and SecureBoot
I need a new firewall so I decided to try a computer from XCY Industrial computers: https://www.aliexpress.com/item/100…order_list.order_list_main.28.1c36180215VyhC
The version i bought was the i5-6300U-6L 2.5G one. This has an Intel i5 Skylake CPU and 6x2.5 Gbps Intel NICs, which is a good setup for a firewall. The motherboard seems to be this one: https://www.shineman.net.cn/en/NSM-GML-6L25-PG7126627
Unfortunately the machine is not production ready. Its Management Engine component is still in Manufacturing mode which means it has no OEM keys, the TPM cannot be enabled, it cannot do hardware attestation and you cannot enable SeucreBoot. A major missing capability in my book. The problem now is that the vendor seems unable to provide a production ready BIOS to enable these feature.
Has anyone on the forum had any experience with computers from XCY or this motherbord and run into, and hopefully solved, similar problems?
Does anyone have the same machine with a functioning BIOS and could dump it for me?
Thanks!
Edit by Fernando: Thread moved into the “BIOS Problems” Category and title customized
