Thanks -68k,
I’ve send a support request to ASRockRack using there web form.
Greetings,
Gafry
Thanks -68k,
Greetings,
Gafry
I’ve got a reply from ASRockRack more or less saying we won’t provide you with a new bios:
Thank you for contacting ASRock Rack support.
Sorry, I checked with Hq but the latest lab X399D8A-2T BIOS even does not support resizable bar.
This is an EOL board and as such it will be difficult to provide a new BIOS for old model.
I’ll give it a try with this extends the live for the board for me, but I have no high expectations…
I will take a look at the latest file for your board.
I’ll send a PM later
-68k
I have an older GA-X99-UD5 Wifi, I have followed the guide on your GH. I have gotten to the part where I am searching for “4G Decod” in the patched bios (although only the Broadwell patches applied) and I cannot locate any variation listed… The closest I have is PFMMIO which is not the same. Can someone help me out with getting resizable bar on this… I am trying to get this thing running an A770 for my wife for XMAS
Hello @LordRelic,
If you can’t get Above 4G decode, you can try to add the ReBAR DXE to the latest BIOS file.
Then try to increase the BAR size
512MB
1GB
2GB
You might not get the full 16GB, but you might notice improvements in performance.
If you se a BAR size that prevents the system from booting, just reset the CMOS.
Good luck
-68k
So this is strange… Above 4G Decod shows as enabled in GPUz but Resizable bar does not… and I cannot find an option to enable it even after extracting the IFR and searching… Not sure what to do.
I also only see 1 Bar and it is 256MB
Unfortunately this BIOS does not work, my computer restart every 2 seconds.
I created a modified version based on the BIOS provided by fidoboy LINK (I replaced the ffs drivers NvStrapsReBar with ReBarDxe and NvmExpressDxe_4 with NvmExpressDxe_5). ReBAR works, but the Intel Management Engine and built-in LAN doesn’t work.
My BIOS: LINK
UPDATE:
Maybe there is something wrong with my EPPROM programmer oryou have to set the Optimized Defaults settings in the BIOS… now it works.
Blockquote
Hey, I was looking to see if anyone can help me mod the MSI Z97S SLI Krait Edition for resize bar support? I was attempting to upgrade my aging PC with a slightly better GPU, but didn’t realize sizebar was a thing and i’m having a lot of problems with my intel arc a750 i’m hoping having resize bar enabled will help.
Hi Guys
Hope one of you can help me. ![]()
I am using an AsRock Z170 Extreme 4, and an RTX 3070.
I cannot for the life of me get Re-BAR to enable.
I have tried using both UEFI tool and MMtool to create the modified BIOS and neither have worked. I can see the driver included in the BIOS in UEFI tool.
Also patching without using the MMtool method results in the bios flasher failing to pick up the bios file.
Can’t see where I have gone wrong?
Setting the Re-BAR size works in the tool but even after restarting twice, and clearing the CMOS it still isn’t working.
I have attached the fresh copy and my modified copy of the bios.
modified_bios_asrock_z170e4.zip (7.7 MB)
fresh_bios_asrock_z170e4.zip (7.7 MB)
If anyone can help it would be greatly appreciated.
-mcg
Greetings @mcg ,
Does the 3070 need a new VBIOS?
https://nvidia.custhelp.com/app/answers/detail/a_id/5165
Good luck
-68k
Thank you so much 68K!
I totally forgot about having to flash the new VBIOS to the GPU.
Thanks again
-mcg
hello @player99 could you share your ASUS Z87-A BIOS with rebar enabled
I also have this mb, and want to upgrade GPU card
thank you
Does anyone have or can make a modded version of firmware for the Gigabyte Z97x Gaming 3 Motherboard.
I bought an Intel ARC B580, but it requires ReBar support.
I’d rather not have to buy a new MB & CPU just right now, and try and squeeze a little extra life out of my old i7 4970k
I am lost in regard on how to accomplish this.
I have F8e running on the BM currently
Many thanks in advance
I’d like a modded BIOS to support Resizable Bar and Above 4G Decoding on my Gigabyte GA-H97-D3H (Rev. 1.0). I couldn’t find Above 4G Decoding in the BIOS Settings and neither could I using UEFI Tool. I found a Memory Remap option with a description that seems to match that of the Above 4G Decoding on other motherboards however it says enabled by default and GPU-Z says Above 4G Decoding is disabled so I really need your help.
I’m new here but I have a question . Is there a way to enable above 4g decoding / rebar and an Alienware 18 r1 viking 2014 haswell ?
Hello everyone!
Hello @JIbICbIU o/
Have you tried removing the card and using the on-board HDMI ?
The Above 4G code might be bugged also.
I’m sure we can make it work.
I can help via PM if you would like.
It get’s messy in the main thread doing support things.
Best regards,
-68k
Hi @68k-dude
No, I haven’t tried to pull out the board and boot via the built-in HDMI.
I thought that the problem might be in the non-working 4G decoding on this f6a firmware. I took the latest BIOS version from the official website and did all the manipulations as in the instructions on GitHub (Enabling hidden 4G decoding · xCuri0/ReBarUEFI Wiki · GitHub), but again I encountered a problem in the file generated in ifrextractor there are no 4G decoding parameters for further actions and I stumbled at this step.
How or where can I write to you in private messages so as not to litter the forum?
Would like help to insert ReBar ( GitHub - xCuri0/ReBarUEFI: Resizable BAR for (almost) any UEFI system ) volume into this BIOS.
The full 16MB BIOS dump is here:
The BIOS can be opened with UEFI tool or Aptio a4, and the module is inserted into that empty space in the screenshot. Despite seemingly having enough space, the insertion shifts the next section either up (UEFI tool v0.28) or down (Aptio) in memory space. Neither version boots when flashed.
Would be good to insert ReBar exactly into that space, shrinking it as needed such that the following block keeps its address.
It appear that this UEFI BIOS is a bit non-standard, which creates all kinds of issues …
Thank you in advance!
i have tried to mod the bios of my asus x99ausb3.1 mobo i used uefi too l to insert the dxe driver for rebar into the bios and the flashed to the chip with my programmer the ran rebar state after startup but it will not work it gives me error 5
these are the screenshots from the bios with the modified driver added that is currently running on my computer what else can i try or am i doing something wrong
