[Request] How do the Bios Switches work. Gigabyte?
On some Gigabyte motherboard’s we have Bios switch’s, the 1st switch is for Main bios or backup bios, the 2nd switch is for single or duel bios.
For me on my Z390 Master I keep them on Main bios and Single.
To enter the backup bios I need, switch 1 on backup bios, switch 2 single bios.
Pre capsule, I could boot in to the backup bios, and then I think it was, swap the 2nd switch to duel bios, then I was able to flash the back up bios to the main bios via Alt F10 Or Crtl F10. Been so long not sure.
Also I tried when in the backup bios, swapping switch 1 from backup to main bios and using qflash flashed the bios hoping as switch is on main maybe it would flash it, yet it seemed to flash, yet it did not flash over the main bios.
Is flashing the backup bios disabled with capsule bios, or did I do the process incorrectly the Alt F10 or Crtl F12?
Last off could I use FPT, booting from the backup bios, save a backup, with fptw64 -d backup.rom then boot to main bios and usefptw64 -rewrite -f backup.romto rewrite the main bios?
Updated !!
So a update after looking around its Ctrl F10 or Alt F10 when the system is booting, yet for me this failed.
Seconded when I tried to flash the main via the switch’s its just the 1st switch swapping from backup to main bios, and then leave the 2nd switch on single bios.
Thanks in advance for any advice.
Edit by Fernando: Thread title shortened
It’s only a MAIN and BACKUP bios aka DualBIOS ™, not like GPU dual bios with profiles, or some GPU also with backup, instead of profile.
mb_manual_z390-features.pdf
I don’t think I have Qflash plus, I don’t have a button?
My Bios is OK, just can’t find nothing on how the switches work or how to try to copy backup to main bios.
So was hoping someone else had.
No, you dont…it has ONLY Q-FLASH buit-in bios, no button.
Read the damm manual of the board will you…
How can I recover main BIOS from backup BIOS (Z390 Aorus Master)? - TweakTown Forums
Nothing more to add, stop being lazy and do your own research, over_n_OUT.
Yes it show’s the switch’s, but nothing on how too correctly use them. E.g to access backup you need bios on single etc
P.s the tweak town post, is my replys from years ago.
Thanks
When I tried swaping the switch to b bios the very first time when b bios was on f10 bios pre capsule, main f13c. The pc would start but not boot and no pc display code. Holing the power button the pc would then restart and boot to backup bios. Once I flashed the backup to F13a off the web that stopped happening but now.
I can set the switch to backup bios and other on single. It still boots to main bios, have to reboot 5 ish times, switching the switch from b bios to main to b bios. So not sure why. Maybe due to the capsule bios change.
Hello!
I would like to help, but on my board the DUAL-BIOS system works automatically - it has no switches.
I use two different BIOS chips winbond 25q128fv on M_BIOS and macronix mx25L12835f on B_BIOS/
Also on B_BIOS - F15b is programmed,
on M_BIOS - F16d
Somehow, yes.
I also use a DIP8 to SOP8 Adapter in M_BIOS - in case something goes wrong.:grinning_face_with_smiling_eyes:
Yea, it’s a good idea, but if all go’s bad I will just cry, an hope i can still return to Gigabyte as they are willing.
Other wise not sure what bios chips I have, m-bios chip can be removed b–bios is soldered.
Also Alt f10 and Ctrl f10, maybe don’t work as im on single bios mode.
P.s how dose the DIP8 to SOP8 Adapter work, is that connected all the time.?
Hi!
So everything is connected, automatic system DUAL-BIOS/
If M_BIOS is damaged - after 4 unsuccessful starts the motherboard automatically boots from B_BIOS.
Then using Efiflash.efi or Efiflash.exe (DOS - version)
and the command:
efiflash.efi [input bios file] /db
or
efiflash.exe [input bios file] /db - (DOS-version)
both BIOS chips are reprogrammed/
I used DIP8 to SOP8 Adapter because my M_BIOS chip is in an 8-dip max. version case/
Thanks/
PS/ Yes, my board does not use personal data - Network Realtek.
So it’s more like the restarts that’s triggered the b bios, yet once on b bios. It will stay untill I swap the switch to main.
Will have to try efiflash. I guess I will have to use the second switch, to duel bios. Once in b bios.
From what i can tell. If switch 1 is main bios and 2nd is Single, it locks b bios access, so it says in manual for safer overclocking.
So when on a OEM or custom bios, bios switch’s may not worked as intended, same for the duel bios. Gigabyte told me.
