[Request] HP ProDesk 400G2 mini BIOS modding
Download Intel CSME 11.6 Firmware Repository and extract file 11.6.13.1212_CON_H_DA_PRD_RGN.bin from it. Rename it to me.bin and copy to DOS USB-stick.
Copy DOS-version of FWUpdLcl.exe from Intel CSME System Tools v11 to DOS USB-stick.
Install your Skylake CPU, boot in native DOS and run:
FWUpdLcl -f me.bin
Power off without rebooting, disconnect power cord for 5 min.
Then power on.
If it boots normally then check with ES CPU (Kaby Lake).
Still not work. I check with SkyLake and confirm that ME is upgraded to 11.6.13.1212. But KabyLake cant boot. Cpu fan run and stop immediately after power button preesed.
Please make new dump now.
Meinfo dump attached
MEINFO_OUTPUT.TXT (8.01 KB)
I meant new BIOS dump with ME upgraded.
Sorry, i got it wrong. The new bios dump attached.
bios_new_me.zip (5.68 MB)
OK. Now we need to test FIT relocating.
Please test this mod with Skylake.
This mod does not work. When i connect the power cord, a red light and a white light keep flashing in turn, and speaker keep alarming. DP no output.
So it’s bad.
Test next mod with Skylake ans ES CPU (Kaby Lake).
The 4th mod with SkyLake:
Cpu fan run and heat sink warn, look like cpu working, but no video out.
The 4 mode with KabyLake:
Cpu fan run and stop immediately after power button preesed, then stay in shutdown status.
So I can’t help you,
Well, you have helped me a lot. Thank you.
What happened afterwards
太可惜了,我也希望这个mod能成功
Hi, DeathBringer, are you a Mod in Bios-Mods Forum?
