Hello, I am here to request help unlocking an Insyde H2O UEFI. I made a post about this subject prior, but I found my previous post to be inadequate in details (See Citations [1]). So after spending a while digging in UEFITool, I am making a new one.
This Insyde H2O is very strange. There is no visible POST or firmware splash and the display initialization only occurs when the OS begins loading. I could not identify any firmware splash/logo (e.g., BMP/EFI logo resources) in the firmware volumes. Setup utils isn’t just option-locked, it won’t even boot into Setup Utils at all. I am not very experienced at anything firmware-related and could use some help please. I have not modified or flashed the firmware yet; this is based only on static analysis of the dump.
Model: Acer AC700-1099
CPU: Intel Atom N570
Board: ZGB
UEFI chip: W25Q32BV
I have an Acer AC700, it is technically a “chromebook”, but I would hardly call it that. It’s one of the first two chromebook models ever created in June of 2011, and as such it predates the Cr50, Write Protect screw, and even Google’s Coreboot-based custom firmware. The device itself has no chromebook specific chips, the ZGB board is simply a standard x86 board for its time.
It may technically be a chromebook, but the Acer AC700 is more of a netbook with ChromeOS. I did not need to unscrew a WP screw or use my SuzyQ cable, it let me in with a CH341A and no write protection whatsoever. I have done firmware modding on Chromebooks before, and assumed I would be able to unscrew the WP screw or solder WP pins and get a custom coreboot payload in under an hour, however I was wrong.
It in fact, uses a (mostly) stock image of Insyde H2O. Google claims this image was “stripped” to only include what ChromeOS needs to boot (See Citations [2]), however after in digging in UEFITool I found that the Insyde H2O image still includes a full, working Setup Utility, CSM boot and CSM fallbacks, storage compatibility modules, and more. Setup Utility’s options seem to be locked off by a mere two variables: Variable 0x85 and Variable 0x86. Setup IFR references what appear to be variable offsets/IDs 0x85 and 0x86 (varstore not yet fully identified). (See Citations [3]).
I have also noticed some strange things about this UEFI though. For one, after examining the UEFI dump in a UEFITool and H2OEZE I could not identify any traditional boot logo (BMP/EFI image) or splash resources in the firmware volume. The only boot logo belongs to ChromeOS and not the firmware. There is no visible pre-boot video initialization or OEM splash; display output begins only at OS boot. I also noticed that NVRAM is very strange, it’s 64kb total with only a small amount of data, the rest is 0xFF. I could not locate Variables 0x85 and 0x86 in VSS Store. I also could not locate F2 handling, in MonitorKeyDxe I found some calls to something called PrePostHotkey but that’s it. I would like to try locating and changing Variables 0x85 and 0x86 to see if that enables some sort of manufacturing/testing mode, however that may not work and there might be some sortof hidden fast/quiet boot option enabled.
On the board there are two chips next to eachother: the W25Q32BV (UEFI) and another chip right next to it, the W25X40BV. I am unaware of the functionality of the W25X40BV, but it may be important so I will be including its dump aswell. After examining the W25X40BV dump in a hex editor, I also noticed the data stream ends in the ASCII string “QUANTA”.
Is Setup likely disabled via Boot Manager or DXE suppression? Could this be a missing or relocated HII database? Where would it be expected for Insyde to store Setup suppression flags? Is it possible Setup is only accessible via Manufacturing mode? Any guidance or help with modding would be appreciated, thanks.
Here are the dumps:
Heres the citations (Winraid only lets new users have two links per post so im keeping all citations here):
