[Request] MSI A15 Thin AI B8VF
I’m looking for an unlocked BIOS for my MSI A15 Thin AI B8VF laptop. Here are my system details:
  • Model: MSI a15 Thin ai b8vf
  • Microcode Patch Level: A705206
  • BIOS version: E16RKAMS.30D
  • BIOS date: 2025-06-27
    *BIOS Vendor : American Megatrends International, LLC.
    EC Version : 16RKIMS2.110
  • CPU:Ryzen 9 8945HS w/ Radeon 780M Graphics
  • RAM: 64GB Corsair Vengeance RAM 5600Mhz
  • GPU: RTX 4060
I’d love to unlock the following features, if possible:
  • XMP profile support and full memory timing control
  • Advanced CPU options (undervolting, power limits, Speed Shift, Turbo Ratio control)
  • Custom fan curve or fan table controls
  • Access to hidden boot/UEFI/CSM settings
  • NVMe and storage-related configuration options
  • iGPU settings, including enable/disable toggle
  • Secure Boot, TPM toggle, and related security features
  • Any other unlocked menus or advanced tuning tools
  • Any hidden Menus or items
  • Unlock where it wont let me boot if i modify certain things
  • *Also unlock the RAM Cap if possible
The laptop is out of warranty, and I fully understand the risks of flashing a modified BIOS. I’m happy to provide a BIOS dump or more system info if needed.
Thanks so much for your time and assistance!
Ajax
EDIT Been playing with the tools you guys have post here in the guides and this is far as i got. I modified file where it i Unlocks all hidden menus and options, removes all trap logic that will hard block you from starting your laptop if you modify certain settings that are flagged and you are forced to hard reset your bios doing the recovery sequence keys and all. NVRAM lock disabled, fTPM/TPM state check bypassed, rollback trigger prevention, Flash write protection & BIOS update restrictions removed, SMM write lock logic removed. I just cant get it to flash through MSI USB formatted to fag32 matehood to flash it which is my ultimate goal to be able to do it that way or something close. Here the file Bios File (1st try)
Second try still cant do usb flash through bios regular method
