[Request] MSI H87-G43 BIOS for TPM 2.0 module
Hello,
I am trying to help a friend with an MSI H87-G43 (MS-7816) and I am looking for a BIOS with properly working TPM 2.0 support.
Some background: about six months ago my friend bought a PC in Germany that was advertised as a “new gaming PC with Windows 11”. The configuration is:
Intel Core i7-4770
16 GB DDR3
GeForce RTX 3050
Windows 11
Unfortunately, he clearly did not get what he thought he was buying. The system is based on a platform from 2013 and the i7-4770 is not officially supported by Windows 11. The computer was not extremely expensive, but for him it was still a significant amount of money.
He only asked me for help recently, about half a year after the purchase, and the German seller has since disappeared and no longer responds.
I am therefore slowly trying to make this PC as usable as possible so that he can at least play the games he bought it for.
UEFI/Secure Boot and the virtualization side are mostly manageable. The main remaining problem is TPM 2.0. This is becoming increasingly relevant because anti-cheat systems such as FACEIT require Secure Boot and TPM 2.0, and some security configurations also depend on VT-x/VT-d, IOMMU and VBS.
The H87-G43 does have a physical TPM header.
The strange part is the BIOS currently installed on this board. It reports itself as:
E7816IMT
V2.14B15 (2019)
This appears to be a non-standard or non-public MSI BIOS build.
What especially caught my attention is the firmware identifier itself. Public H87-G43 BIOS releases normally use the E7816IMS naming scheme, while this firmware identifies itself as E7816IMT.
I have not been able to determine where this E7816IMT V2.14B15 build came from.
Does anybody know what the “T” suffix in E7816IMT means?
Was this an internal MSI BIOS, beta/support release, engineering build, OEM-specific firmware or something distributed privately by MSI support?
I would also be very interested in any changelog or information about the origin of this BIOS.
With this BIOS, TPM support seems to be partially implemented but not working correctly.
Initially, after enabling TPM/Trusted Computing in BIOS, the system appeared to detect the TPM. Windows could also see that something was present, but the TPM remained inactive/not ready.
I could not successfully prepare or initialize it from Windows.
The activation/initialization option in BIOS was greyed out.
After several reboots, for reasons I still do not understand, the TPM disappeared from the BIOS completely.
I now have a second TPM 2.0 module available for further testing, so I can rule out the module itself more thoroughly. However, the previous behaviour makes me suspect that the real limitation is in the H87-G43 firmware or TPM initialization code.
What I am looking for is:
  1. A newer internal/beta BIOS for the MSI H87-G43, if one exists.
  2. A BIOS version with properly working discrete TPM 2.0 support.
  3. Alternatively, information about whether E7816IMT V2.14B15 can be modified to correctly initialize and expose TPM 2.0.
  4. Any information about the origin of the E7816IMT branch and what differentiates it from the normal E7816IMS BIOS releases.
  5. A changelog or release information for V2.14B15, if anybody has it.
    @MeatWar - I noticed that you previously worked with modified BIOS images for the H87-G43 and other MSI MS-7816 boards. If you happen to know anything about the E7816IMT branch, have any later H87-G43 MSI beta/support builds, or know whether proper TPM 2.0 initialization can be added or fixed in this firmware, I would greatly appreciate your input.
    Thanks for any information or help.
I can’t…no recall of such branch or any beta bios or any bios for this model with TPM2.0 support.
There are several models with the MS ID 7816…but i never saw any IMT
Also, i do not recall seeing MSI doing to any user, a bios for TPM 2.0 support, these boards header only support TPM1.2 (and don’t even think of PPT, no chipset/cpu support)
If a TPM2.0 module can work on the latest official bios and supported…really don’t know.
Some users got some non-public bioses to support TPM2.0 modules but on Intel 9 Series…not on 8 series, that’s all, you may wait for other users PoV.
Thank you for your answer — I had the most hope in you :). Nobody else has replied for two days, so I guess probably no one else will be able to help me with this.
Does anybody know if the MSI forum or MSI support could provide me with anything more than what is already available? I see traces of newer BIOS’es for this MB but without available download.
In my opinion, MSI has always provided great long-term support for their hardware. In the past, they usually had updated VBIOS or BIOS versions available even many years after a product was released. Sometimes those updates were not published publicly and were only shared after someone requested them on the forum.
It seems that MSI has now stopped sharing this kind of information/software/firmware/BIOS through the official forum. Does anybody know what the proper way to request such files is nowadays?
Maybe they have something from around 2020–2021 released for the IMS branch rather than IMT.
Don’t get any hopes for such files in 2026… some things changed indeed in MSI forums, still you can try to share the info there, maybe somelse has some details on this IMT branch, but i don’t believe you’re going to get their support on a TPM2.0 bios on Intel 8 series, from MSI.
Good luck.
