[Solved] GA-H55M-S2: Power/Reset buttons not working, ME error
Flash Image Tool just gets stuck on my dump for some reason.
That’s sad.
(No further information given or files provided)
I can’t upload files due to being a new user.
Contrary to the stupid ass embed, this is a file link
Take the already cleaned ME region from the outimage.bin in #16
(0x1000 to 0x600000)
I don’t need the ME Region, I already have it from the repository.
[quote=“lfb6, post:13, topic:94414”]
In the ‘filename’\decomp folder cut the first 0x600000 from ‘Bios Region.bin’, resulting file should be exactly 0x300000, stock GB bios region in 0x200000 to 0x300000.[/quote]
How do I do that? I’m using Gabubu’s SPI.bin file because I couldn’t figure out how to use their outimage files.
I used a fixed SPI.bin file from a thread for the same issues with a H55M-S2V motherboard on this website and it looks like I destroyed the chip. The PC shut off at 4% erased. It turns off normally now but I can’t enter the BIOS settings and Windows doesn’t detect the ME.
Is it possible to make it enter BIOS settings now? Maybe properly disabling the ME (IIRC there are ways to do it) would help?
What do you read in the guide?
" Since the purpose of the guide is to clean the DATA section, it is important to choose a clean RGN Engine firmware from the Intel Engine Firmware Repositories thread and not EXTR which is extracted from various SPI/BIOS images/dumps and considered dirty as far as the DATA section is concerned. Moreover, a full RGN Engine Region is required and not an Update (UPD) image. That means that you should look only for Engine firmware of this structure at the Repositories:"
But there’s a clean ME already as instructed here
