[Success] Lenovo M70Q BIOS - CFG Lock & OC Lock Removed
Ive OC / Undervolt unlocked my Intel NUC, and later an ASUS and Dell laptop BIOS’s which were pretty straight forward, as they all had normal .ROM files…and i didnt find that daunting at all, once youve done one…easy peasy.
But i now have Lenovo M70Q Gen 2, and when starting off on the same journey, i came across conflicting reports that these could only be OC/UV unlocked by physical chip access OR by doing the usual BIOS edit (which comes with some new stuff for me)
So not sure which is true for starters
On the BIOS front, i went to start on that path, but apparently it has a header (capsule) and in UEFITool the initial hex view reads:
AMIPFAT AMI_BIOS_GUARD_FLASH_CONFIGURATIONS
Just wondering if this is at all software fixable or hardware only
Not afraid to say out of my depth on this one
Any help/advice appreciated
BIOS Lenovo M70Q Gen 2 v1.71 linked below
https://www.dropbox.com/scl/fi/1tjhyh8nnkdot0l4ds2nb/Lenovo-M70Q-Tiny-Gen-2-m3jjy47usa.zip?rlkey=fd3nnz2e4cnak79rzeljjuh6r&st=pb7n6dr3&dl=1
Intel B560 chipset… has some limitations.
Flash could be useful the ME_DIS jumper
A spi programmer as backup/flash device is advisable, especially for backup the 2 IC’s on each side of the board.
platomav/BIOSUtilities: Collection of various BIOS/UEFI-related utilities which aid in research and/or modding purposes.
Appreciate the link and info, i was hoping for a bit more guidance whether its possible with the programming hardware and just a (modded) BIOS flash, and how to deal with the “AMIPFAT AMI_BIOS_GUARD_FLASH_CONFIGURATIONS“ header
Thanks
Didnt i mentioned already…an SPI programmer…
a “modded” file…sure, if you know what you’re doing, the programmer will write everything, a bad or good mod.
Already pointed you the required tool to extract… AMI BIOS Guard Extractor
After, opening the firmware with UEFI tool, will show the different volumes of it, yellow/red marked ones, when touched may lead to security break and a bad mod, systems usually get “death” when flashed, so if your mod requires any modifications on these areas, i do not advise so.
Sorry there was a typo in my last post, it was meant to read:
whether its possible with the programming hardware (and a modded BIOS file)
OR
just a (modded) BIOS flash (as i have done successfully before on my NUC and laptop - modded bios flash like usual) with NO programming hardware needed
My apologies
I appreciate the added content/context, as i was not sure what tools you were referring to or its use. thats much clearer thanks
im guessing that the following info noted by arrows in pics means a standard bios flash if modified would end in tears and i need the hardware programmer?
You’ll have to look for it and try several options, like Intel FPT using ME_DIS jumper if available, option in bios to disable it can sometimes be present, Grub and RU, etc… mod files wont be flashed by regular methods due to security features.
Most likely…changes are high.
Seems to me you’ve not have enough experience to deal with this…without the proper tools and time to recover death systems so i advise not to engage in such actions.
Go read some threads about Lenovo systems mods, that’s all, good luck.
I have changed BIOS options via grub and set var before and FPT, so ill investigate that and also buy the hardware programmer as well. have read posts on that side of things, and not too concerned if thats the path - ill backup the current BIOS with the programmer before i do anything
Cheers
Resolved :slight_smile:
Okay, so i was trying to do the work before i got the unit itself - im a forward planner :slight_smile:
But in this case that was impossible as the tags and offsets for OC Lock and CFG Lock didnt exist in the downloaded and extracted .cap file
So last night when i got the unit i dumped the devices onboard BIOS with the Intel Flash Programming Tool
Only then when using UEFITool did i find CFG Lock and OC Lock, and when exported and extracted in verbose mode via IFRExtractor, the offsets were found and i had no trouble then booting my easy2Boot USB, and loading modGRUBShell, and issuing the setup_var_cv lines:
CFG Lock
setup_var_cv CpuSetup 0x3E 0x01 0x00
OC Lock
setup_var_cv CpuSetup 0xDA 0x01 0x00
as both did the somewhat usual thing of saying they didnt process what they expected, i then loaded RU.efi and double checked in hex at those offsets
Rebooted, turned off Memory Isolation in Windows 11, and ran ThrottleStop and all was unlocked as normal
Of course this was on the current BIOS version as received, and i know (as i have it) theres a BIOS update to do. I have seen the offsets stay the same post update, but you never know, so ill double check with a bios dump and UEFITool and IFR Extractor post update and note if they changed in case its useful to anyone else.
What seemed possibly daunting and involving my first potential use of a hardware programmer was in the end as easy as when ive done NUC’s and my laptops
Update:
No change for offsets on BIOS update for me at least
