In order to avoid problems with antivirus software, the next build will use the MCE.py file instead of MCE.exe.
For correct work with microcodes you need to install the Python package.
https://www.python.org/downloads/
You will also need to install the libraries:
- colorama
– “pip install colorama”
- PLtable
– "pip install pltable"
If you have questions, then discuss here
[Discussion] UBU Tool related Questions, Reports and Suggestions
PS Installing Python will give you some advantages. You will be able to launch Python applications, of which there are a lot.
UEFI BIOS Updater v1.79.3
- Changelog:
- Changes to the script.
Updated:
Microcodes
- MCE.py v1.43.1 (Python Source code/Script)
– removed MCE.exe
- MCE DB r152
Note
* Starting with this version of the UBU, for the correct operation of the MCE, a Python of 3.7 or higher is required.
See the previous post.
- You can use MCE.exe, download it yourself and do not complain about the alleged presence of a virus.
UEFI BIOS Updater v1.79.4
- Changelog:
- Improved AMD microcode replacement.
Updated:
Microcodes
- MCE.py v1.44.0 + DB r153 - Utilities
- mCodeFIT v0.6.12
Note
* - MCE.py and MCE.db - Now you can update from UBU.
More thanx to plutomaniac!
UEFI BIOS Updater v1.79.6
SoniX cannot login due to captcha input problem.
UEFI BIOS Updater v1.79.6.1
- Changelog:
- Updated:
- LAN
- EFI Realtek Undi v2.054 - Microcodes
- MCE v1.48.0 + DB r157
- Added new AMD mCodes - Utilites
- mCodeFIT v0.7.0
UEFI BIOS Updater v1.79.6.2
- Changelog:
- Updated:
- Video
- EFI AMD GOP Driver v2.12.0.0.0
- OROM AMD Cezanno v017.010.000.021.000000
- OROM AMD Renoire v017.010.000.021.000000 - Utilites
- DrvVer v0.27.6
UEFI BIOS Updater v1.79.6.3
- Changelog:
- Updated:
- Microcodes
- MCE DB r158
- Inetel mCodes (DT) KBL, CFL, CML (#504)
UEFI BIOS Updater v1.79.7
- Changelog:
- Displaying information about MB and BIOS,
- Changed by OROM LAN Qualcomm-Atheros as Lx Killer E2xxx
- Updated:
- Microcodes
- MCE 1.48.1 with DB r159 - Utilities
- DrvVer v0.28.0
UEFI BIOS Updater v1.79.9
- Changelog:
- Fixed #1468
- Updated:
- Video
- EFI AMD GOP Driver v2.13.0.0.0
- OROM AMD Cezanne and Renoir - LAN
- EFI Intel PRO1000 Undi - v9.4.06 - Microcodes
- MCE DB r165
- latest Intel and 1151, 1200 AMD AM4 - Utilities
- DrvVer v0.28.1
- OROMReplace v0.3.3
Not official - Testing
UBU 1.79.10 beta
- Fixed result replaced OROM #1483
- UEFITool’s NE A58
- MCE v1.50.0
– if use prevision version MCE.py need update PLTable #1490
UEFI BIOS Updater v1.79.10
- Changelog:
- Microcodes
- MCE v1.51.0 with DB r166 - Utilities
- UEFITool’s NE A58
- Fixed - Discarding the OROM version after replacement if OROM is in a third-party GUID.
[list]Updated:
If you are using MCE.py (Source Code), be sure to update PLTable.
1
2
3
2
3
pip install --upgrade pltable
UEFI BIOS Updater v1.79.11
- Changelog:
- Found bugs fixed.
- Updated:
- Disk controller
- EFI AMD RAIDXpert2 v9.3.0-00221
- OROM Marvell 92xx v1.0.0.1028 - Video
- EFI AMD GOP Driver v2.14.0.17.10
- OROM AMD VBIOS Cezanne - 017.010.000.027.000000
- OROM AMD VBIOS Renoir - 017.010.000.027.000000 - LAN
- EFI Intel Gigabit Undi v0.1.00
- OROM Broadcomm Boot Agent v20.14.2 - Microcodes
- MCE v1.52.1 with DB r169 - Utilities
- DrvVer v0.28.3
UEFI BIOS Updater v1.79.12
- Changelog:
- Share OROM AMD VBIOS
- Updated:
- Video
- EFI AMD GOP Driver v2.15.0.17.10
- OROM AMD VBIOS Cezanne & Ranoir - 017.010.000.028.000000
- OROM AMD VBIOS Picasso & Raven/Raven2r - 016.002.000.012.000000 - Microcodes
- MCE v1.52.2 with DB r171
Upd:
UEFI BIOS Updater v1.79.12.1 (29.12.2020)
- DrvVer v0.28.4
UEFI BIOS Updater v1.79.15
- Changelog:
- New pattern for searching for EFI Intel LAN.
- Improved work with GOP drivers.
- Changed ‘Files\Intel\GOP’ folder.
- Support Intel GOP Driver TigerLake (RocketLake)
- Found bugs fixed.
- Updated:
- Disk
- EFI AMD RAID Xpert 2 v9.3.0-00256 - Video
- EFI Intel GOP Driver SKL+ v9.0.1111
- EFI Intel GOP Driver TGL+ v17.0.1055 - LAN
- EFI Realtek UNDI v2.055 - Microcodes
- MCE v1.52.6 with DB r181
- Some microcodes for AMD and Intel - Utilities
- DrvVer v0.28.7
- OROMReplace v0.3.4
UEFI BIOS Updater v1.79.16
- Changelog:
- Found bugs fixed.
- Updated:
- Video
- EFI Intel GOP Driver TGL+ v17.0.1058
- EFI AMD GOP Driver v2.16.0.17.10
- OROM AMD VBIOS Cezanne and Renoir v017.010.000.029.000000 - Microcodes
- MCE DB r185
- Microcodes for Intel LGA 1151v2 - Utilities
- DrvVer v0.28.8
New download link from 20/04/2021.
https://mega.nz/folder/lLg2GLrA#SnZZd0WjHkULFHg7FESm8g
UEFI BIOS Updater v1.79.16.1
- Changelog:
- Fixed #1678-1679
- Updated:
- Microcodes
- MCE v1.53.0 + DB r186
+ CPUID 606Ax
UEFI BIOS Updater v1.79.16.2
- Changelog:
- Updated:
- Disk
- EFI AMD RAID Xpert 2 v9.3.0-00266 - LAN
-EFI Realtek UNDI v2.056 - Microcodes
- MCE v1.60.0 + DB r190
UEFI BIOS Updater v1.79.16.3
- Changelog:
- Updated:
- Video
- EFI AMD GOP Driver v2.17.1.17.10
- EFI Intel GOP Driver Tiger Lake v17.0.1059 - Microcodes
- MCE DB r192
- Some Intel & AMD (AM4 00A20F10/F12) mCodes
