Z390 Dark Skylake
Hi all, So recently I have gotten a bios mod from chino which was perfect. But when I went to flash it on the dark the post code either got stuck at a6 or kept jumping from 30 to 35 then 29 then 36, etc but no change after that. I was wondering if anyone is able to create a z170 Dark bios which has all the firmware downgrated to the skylake as well as mc and me? Thanks a lot for the help!
@seranidy Here is another BIOS you can try with both the HAP bit disabled (as with the previous modified BIOS) and ME disabled using AMIBCP.
107mod2.zip
It may make no difference to the boot error as we discussed in PM.
