7700t es on Zoltac B150
Greetings, I’m trying to run a QKYL on the Zoltac B150 board. MC Extractor confirmed that BIOS already contains the latest microcode for 560E8 but no POST still. Any help would be appreciated!
0506E8h? Everthing looks ok on the paper.not a detailed supported list but alright
Latest bios version is 2K180410 (update to it if you have not already)
You may need to check your bios settings.
Load defaults,save&exit,re-enter bios,set optimals then clean install your windows
Thanks for the input! However I’m still stuck with no display, 1 long and 3 short beeps from the AMI bios. The motherboard is tested with another working CPU and RAM.
Try to disable ME HAP-bit.
