@Kuri0 It is possible to fix the DSDT in the motherboard z97 aniverssary .
It seems to be the same with asrock z97 extreme 9 that you fixed.
It seems to be exactly the same.
If you fixed it can i enabled /disabled it from the sabmenu that i unlocked?
@boombastik you will always see Large Memory even with 4G Decode off due to how the DSDT is made. Usually there’s an If statement to disable if it 4G Decode is off but I don’t know the variable which contains that state on your DSDT (on mine it’s MM64 for example) so I just made it always on.
Also there’s usually an If statement for legacy OS (XP I think) but I couldn’t be bothered to put that
@Kuri0 thanks for the explanation.
Do you know why in this motherboard with csm and above 4g works?
In newer motherboards the above 4g cant work with csm.
@boombastik Does your BIOS graphics become low resolution or text mode ? On mine enabling CSM and above 4G makes the BIOS in text mode can’t even access setup or boot from device.
@Kuri0 the graphics go in low resolution as intended in csm mode and all works normally and i can boot from whatever i want.
Also all these asrock ,msi, asus (haswell era) motherboards cant boot in uefi mode without a monitor in gpu. They revert in csm.
I tried with other modders included myself and we cant make it to work. Do you know if it is possible to boot headless (without a monitor connected) in UEFI mode?
You still need to have it enabled otherwise the Large Memory is not actually used although it shows. You can see in your screenshot that none of the devices use memory addresses above 4GB when it’s disabled.
@Kuri0 One last question.
When i open the device manager and go to my gpu rx580 i don’t see large memory on resources.
It is because the way you implemented this.
Because here in photo under memory there exist devices that in fact use large memory (despite that there are on memory) :
