Used INTEL-SA-00075 Discovery Tool to check ME firmware and I’m just curious why this laptop has 6.0.30.1203 if latest (based on this site) is 6.0.30.1199. And question is: can I upgrade to version 6.2.50.1062 ? How to recognize if I have
this
Intel ME 6 1.5MB Firmware v6.2.50.1062
For 5-series (Ibex Peak) systems which come with ME firmware v6
or this
Intel ME 6 Ignition Firmware v6.0.30.1199
For 5-series (Ibex Peak) systems which come with ME Ignition firmware v6
MEInfo
Intel(R) MEInfo Version: 6.0.50.1252
Copyright(C) 2005 - 2009, Intel Corporation. All rights reserved.
PMXUtil: Error during PMX Call: PMxDrv!PCI - Failed Call to OS_SafePCI
PMXUtil: Error during PMX Call: PMxDrv!MAPPHYS - Bad Input Parameters
Error 9269: Access to SPI Flash device(s) failed
Intel(R) ME code versions:
BIOS Version: V1.16
MEBx Version: 6.0.3.19
Gbe Version: Unknown
VendorID: 8086
PCH Version: 400006
FW Version: 6.0.30.1203
UNS Version: 6.0.0.1202
LMS Version: 6.0.30.1202
MEI Driver Version: 6.0.0.1179
Wireless Hardware Version: Not Available
Wireless Driver Version: Not Available
FW Capabilities: 7264
Intel(R) Anti-Theft Technology PC Protection
Intel(R) Capability Licensing Service
Protect Audio Video Path
Cryptography Support: Disabled
Last ME reset reason: Power up
BIOS and GbE Config Lock: Unknown
BIOS boot State: Pre Boot
FWU Override Counter: Never
FWU Override Qualifier: Always
Local FWUpdate: Enabled
OEM Id: 00000000-0000-0000-0000-000000000000
FW behavior on Flash Descriptor Override Pin-Strap: Halt
Your system is not vulnerable to INTEL-SA-00075/CVE-2017-5689 because it is a 1.5MB (Consumer) system. You can update to Intel ME 6 1.5MB Firmware v6.2.50.1062 if you like via FWUpdate tool.
C:\Users\tadek\Downloads\Intel ME System Tools v6 r2\Flash Programming Tool\Windows>fptw.exe -f 6.2.50.1062_1.5MB_PRD_UPD.bin
Intel (R) Flash Programming Tool. Version: 6.0.40.1214
Copyright (c) 2007-2010, Intel Corporation. All rights reserved.
Platform: Intel(R) HM55 Express Chipset Revision: B2
Reading HSFSTS register… Flash Descriptor: Valid
— Flash Devices Found —
MX25L3205D ID:0xC22016 Size: 4096KB (32768Kb)
PDR Region does not exist.
Error 25: The host CPU does not have write access to the target flash area. To enable write access for this operation you must modify the descriptor settings to give host access to this region.
Any idea how to do it ?
Ok solved.
Used meset.exe and flashed corerctly.
Thanks
You used the wrong tool, you should use the FWUpdate fwupdlcl instead.
AFAIK the MESET.exe is intended to be used on CLEVO laptops only, I have never known that it works on other brands.
